Timing chain tensioners
Old Jun 1, 2012 | 06:58 PM
jaysjag's Avatar
Question Timing chain tensioners
1999 XK8, looking for a U.S supplier for a rev 3 tensioner replacement kit that includes bolts and gaskets. I saw a thread awhile back that listed one that sold other combinations that included the guides, but now can't find it ? I don't have the types of tools needed so I'm also looking for a mechanic in the Houston area to install.
Old Jun 1, 2012 | 07:40 PM
You can use Ford tensioners the info is in this thread https://www.jaguarforums.com/forum/x...-number-63055/ the gaskets vary so pay attention to the info also in that thread.
If you are in Houston you are close to one of the techs members-Brutal.
You could do worse than contact him and see if he is interested.
As a newbie you can't PM him, if I were you I'd get over to the New Members section and post an intro, with luck our admin will happen by soon and upgrade you to full access.
As
Old Jun 1, 2012 | 07:41 PM
test point's Avatar
Welcome to the forum Jay!
The on-line Ford/Lincoln dealers have proved to be the low cost suppliers of tensioners and bolts. Your car, a '99, can use the FelPro gasket set for the '00 Lincoln LS/Ford Thunderbird at half the price of Jaguar labeled parts. Available at any auto parts store for less than $40.
Ford part numbers and lots of other info can be found here:
https://www.jaguarforums.com/forum/x...34/#post330655
Post #4 has the Ford part numbers.
Old Jun 1, 2012 | 09:55 PM
jaysjag's Avatar
Thanks again, I've posted an intro, but in the meantime could you give him a heads-up to my problem. Not sure though if I want to use ford parts, isn't that who installed the crappy tensioners in the first place.
Old Jun 1, 2012 | 10:25 PM
Paul Pavlik's Avatar
Jaguar is the only source for the Metal Bodied Tensioners.
The parts marketed by Ford are Jaguar Parts.
In fact, the Parts from Ford will say Jaguar on the Package.
Of course, the FelPro Gasket Set is Aftermarket.
Old Jun 1, 2012 | 11:58 PM
AB22 Easy Tiger's Avatar
I see you have a very good recommendation on this thread, but if that doesn't work out, call Tony at Today's European Cars on Richmond.
Although they don't broadcast it, they are very good with Jags.
Old Jun 2, 2012 | 06:14 AM
I have sent a PM so stand by and see what happens.
Old Jun 3, 2012 | 01:31 PM
Brutal's Avatar
well your pm's are open yet so I can pm you. I can do it. how many miles and you really only need the upper done prevantativly..... unless yours has come apart already and caused damage
RoyLittle0
May 25, 2023 02:38 AM
Jpav27
Jul 31, 2022 06:43 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Bowman
Sep 15, 2015 06:54 AM
Bowman
Sep 3, 2015 03:17 PM
