Top engine rattle
Old Mar 24, 2014 | 09:07 AM
mctb's Avatar
Default Top engine rattle
Today i have removed my cam covers to have a look at the chains and VVT as i have a rattle at start up and it doesn't go away, looking at the Tensioners they are 2nd gen and seem to be in good condition have used a borascope to have a look around and cant see anything obvious why there is a rattle, chains are tight no apparent damage, any ideas one thing i did notice one of the solenoid shafts seems to be further in
Old Mar 24, 2014 | 10:55 AM
any way to post a sound clip or video - it may help to assist in identifying the potential cause.
regards,
Steve
Old Mar 24, 2014 | 01:31 PM
test point's Avatar
Please replace the tensioners while you are there. That is absolutely needed will remove one source of rattles from discussion. The belt tensioners are the second most common source of front of the engine noise. You can confirm that as the problem be removing the belt after you button up the valve covers.
Old Mar 24, 2014 | 03:52 PM
DpezXK8's Avatar
If there 2nd gen I'd change them. Mine looked fine too until I replaced them. Even the dealer at the time said they were fine when I had them inspect them.
Here's the link to to thread I dealt with. There are pic's of the tensioners on later pages.
Help Guys, Burning Oil
Hope this helps
Old Mar 24, 2014 | 04:32 PM
DpezXK8's Avatar
Here's another one for you
Do you need another warning? Tensioners
D.K
Dec 10, 2023 02:05 AM
obwoodie
Sep 3, 2015 07:45 PM
pocketrocket
Sep 3, 2015 07:44 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
