Top latch lock
Old Aug 9, 2021 | 12:19 PM
jonnb33's Avatar
Default Top latch lock
I have a hose leaking to the headliner, can these hoses be disconnected some how at the pump and plugged at the pump and unlatch the top manually to lower it?
Old Aug 9, 2021 | 01:05 PM
Phil m's Avatar
Having recently had issues with my roof you should find lots of useful information in the tread.
https://www.jaguarforums.com/forum/x...7/#post2426278
Old Aug 9, 2021 | 01:37 PM
jeremys's Avatar
It’s possible to cap of the line going to the latch at the pump then use the manual Allen key to raise and lower the latch, there is a write up on this somewhere. I did it it works fine. If I find it I will forward or perhaps someone else knows where it is replacing the line is a pain this issue happened to a lot of cars in high temperature zones sun on the front cracked the fitting, typical Jag under engineered.
Old Aug 9, 2021 | 05:36 PM
jonnb33's Avatar
I would appreciate it, thank you
Old Aug 9, 2021 | 09:15 PM
Dennis07's Avatar
There is a link in my signature line below to the info you'll need to convert to manual latch operation. Since I no longer have an xk8 I don't check in here very often, so send me a PM if any questions arise.
Old Aug 10, 2021 | 08:47 AM
jonnb33's Avatar
thank you so much, I am going to disconnect the latch hoses at the pump and install plugs in the pump, and unlatch and latch manually
Old Aug 10, 2021 | 09:08 AM
jeremys's Avatar
Denis07 manual latch link is what I used works well.
Old Aug 10, 2021 | 01:07 PM
CA Jag's Avatar
Suggests on an easy place to get the compression nuts and blanking plugs? Just did Google and got a variety of parts. Denis, thanks for your possible source but are there other options?
Old Aug 10, 2021 | 02:10 PM
CA Jag's Avatar
Just ordered from Malone's. Nice guy. He gets 3-4 orders/year from this forum. He's heard all the green shower stories.
Old Aug 10, 2021 | 07:15 PM
jonnb33's Avatar
Default green shower
thank you all for your help
marvin.d.miller
Sep 3, 2024 06:45 AM
cdre
Jul 14, 2017 04:44 AM
Jay48
Sep 7, 2015 09:30 PM
Dr. D
Jun 10, 2013 04:39 PM
OhioXK
Jun 21, 2012 10:15 PM
