Traction Control Fail and Stability Control Fail
Old Jul 8, 2018 | 09:51 AM
psheffie's Avatar
Default Traction Control Fail and Stability Control Fail
My 1999 XKR has had its battery disconnected for six weeks and on reconnecting to start the car I get two fail messages 'Traction Control and 'Stability Control' . Can this have anything to do with disconnecting the battery for a long(ish) period and then reconnecting?
Old Jul 8, 2018 | 10:45 AM
motorcarman's Avatar
Do the messages stop when the car is started and the alt is charging??? Low battery!!!
If the messages are displayed all the time, then DTC(s) is/are stored in the ABS module.
C1095 is common for the pump motor circuit fault (board solder). Could be wheel speed link harness??
Let the guessing begin.
bob
Old Jul 9, 2018 | 01:17 PM
iRuslan's Avatar
After driving 5-10 miles turn off the engine. And turn on and no more messages about traction & stability. Off course if the battery in normal condition.
Old Jul 9, 2018 | 01:58 PM
The most precise way to diagnose the fault is by getting the DTCs directly from the module. Otherwise we can all guess.
bob
Old Jul 10, 2018 | 11:26 AM
iRuslan's Avatar
bob
Tell me please model of aftermarket diagnostic scaner, which can take DTC directly from modules from 1998MY xk8 4.0L.
Only WDS from Genrad, Autologic or may other correct equipment can do this?
Just Mangoose will not working with my car, WDS temporary unavailable, Autologic high expensive.
JimC64
Sep 22, 2025 02:52 PM
Timothy J. LaPean
Oct 17, 2016 03:44 PM
charlie.p
Oct 5, 2016 09:12 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Mar 16, 2006 03:10 PM
