Traction Control Fail and Stability Control Fail
My 1999 XKR has had its battery disconnected for six weeks and on reconnecting to start the car I get two fail messages 'Traction Control and 'Stability Control' . Can this have anything to do with disconnecting the battery for a long(ish) period and then reconnecting?
Do the messages stop when the car is started and the alt is charging??? Low battery!!!
If the messages are displayed all the time, then DTC(s) is/are stored in the ABS module.
C1095 is common for the pump motor circuit fault (board solder). Could be wheel speed link harness??
Let the guessing begin.
bob
bob
Only WDS from Genrad, Autologic or may other correct equipment can do this?
Just Mangoose will not working with my car, WDS temporary unavailable, Autologic high expensive.
JimC64
Sep 22, 2025 02:52 PM
Timothy J. LaPean
Oct 17, 2016 03:44 PM
