trans problem
Old Mar 5, 2018 | 06:23 PM
magnum454's Avatar
Default trans problem
ZF trans makes grunting noise as if I'm backing over something. Forward seems to lock up until I give it more throttle.
Old Mar 5, 2018 | 06:30 PM
JBzXJ40's Avatar
What year XK do you have - 2 different transmissions available
Are these symptoms there all the time or do they go away after cycling the ignition?
Old Mar 5, 2018 | 06:35 PM
magnum454's Avatar
TNX. 2000XK8 I think it's a ZF5
Old Mar 5, 2018 | 06:37 PM
dsnyder586's Avatar
I'm gonna try and guess what you mean-
1. When you back up it struggles to engage, but moves
2. When you go forward, it doesn't engage until the revs come up, but then goes
Correct? If yes, classic A-drum.
Old Mar 5, 2018 | 06:38 PM
magnum454's Avatar
Sorry, the problem just started. It happens every time I start the car.
Old Mar 5, 2018 | 06:41 PM
magnum454's Avatar
dsnyder, that's close. Good guess. U think it's the A drum?
Old Mar 5, 2018 | 06:57 PM
JBzXJ40's Avatar
From what you describe I would agree with dsnyder - but when this problem started, did you put it into gear, then as you press accelerator it revs up then bangs into gear? This is what usually happens with the drum breaks.... "might" still be something else.... Torque converters have given issues in the 5HP24 as well.
Do you have any warning lights on the dash?
Old Mar 5, 2018 | 06:58 PM
RJ237's Avatar
Yes. Don't drive to avoid causing more damage.
Fairfalcon
Jan 28, 2018 02:04 PM
JaguarXKR
Aug 8, 2013 11:38 AM
WhiskyTangoFoxtrot
Jun 16, 2011 08:48 AM
kenc
Jul 3, 2010 03:59 PM
Apr 3, 2007 02:20 PM
