Transmission Fault, P1111, P1121
Old Aug 17, 2014 | 11:00 AM
teckwing's Avatar
Default Transmission Fault, P1111, P1121
Yesterday I took my 2000 XK8 convertible out for a nice evening drive in the country. After accelerating fairly aggressively from a stop sign up to 60 mph the engine powered down and went into limp mode in 2 miles.
The following messages appeared: Transmission Fault, Traction Control Not Available, ASC Not Available, Fail Safe Engine.
OBD2 codes: P 1111 (System Pass), P 1121 (Pedal Position Sensor A Circuit Range/Performance).
As a historic note pertaining to the Transmission Fault, I purchased this attractive car in 2010. At the time the mileage was 68,000. At approximately 69,000 miles my Jaguar technician changed the transmission fluid with a recommended NAPA fluid and filter. The transmission developed a squawk (screech) under acceleration so a additive was added. This did not quite eliminate the noise but it does go away after 30 minutes of driving. The car now has 74.000 miles.
Lately I have experienced a hard shift into first when getting off the brake after a quick stop.
Is a transmission rebuild in my future or possibily a primary control valve??
Any thoughts and experience would be greatly appreciated.
Tom
Old Aug 17, 2014 | 11:03 AM
JagV8's Avatar
Any chance your battery is starting to fail?
Old Aug 17, 2014 | 11:08 AM
motorcarman's Avatar
The ECM codes you see are not TCM.
You might have more DTCs in the TCM but cannot read them with a generic scanner.
You need to read the SERVICE ACTION S484am. It is a TSB issued in December 2001.
You might already have the correct INST PK rear cover????
Better to look to be sure.
You might also just have a failing gearbox and a faulty ABS module????
bob gauff
File Type: pdf
Old Aug 17, 2014 | 11:11 AM
teckwing's Avatar
I had not considered that. The battery is a 2 year sealed old dry cell and is kept on a maintance charge.
I will check it out, however.
Thanks for the feed back.
Old Aug 17, 2014 | 11:58 AM
Gus's Avatar
Gus
Should you have a problem with the throttle body position sensor you will get a code P1121 and the transmission fault, traction control failure and fail safe. You can have the battery checked but chances are you need the throttle body position sensor rebuilt.
Old Aug 17, 2014 | 04:22 PM
teckwing's Avatar
OK
Thanks for the advise. I will start with the sensor rebuild.
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
picard
Oct 12, 2015 11:56 AM
SouthernGypsy
Sep 23, 2015 04:06 AM
tonyforman
Sep 10, 2015 07:23 PM
