Transmission rotary switch disconnecting
Old Nov 22, 2025 | 10:49 AM
daveb97's Avatar
Default Transmission rotary switch disconnecting
Hi all need help I am trying to remove the transmission rotary switch on my 97 xk8 I found the plug behind the throttle body but how does it disconnect it is hard to see, I can get my hands on it were is the tab that releases it. I have tugged to no avail any help would be greatly appreciated. I am getting the dreaded P706 code every so often
Old Nov 22, 2025 | 11:31 AM
motorcarman's Avatar
The D4 switch is more of fault than the Rotary Switch.
I would investigate the D4.
File Type: pdf
Old Nov 22, 2025 | 11:32 AM
michaelh's Avatar
This post of motorcarman's may help as he also shows the plug:
https://www.jaguarforums.com/forum/x...7/#post2696576
Old Nov 22, 2025 | 11:57 AM
daveb97's Avatar
Thanks I just checked the rotary switch I think it's OK it also is the black cover one so it must have been replaced at some point do you guys know if the black cover ones are compatible with a 97Xk8, I will move on to the D4 switch as well. Thank you for the quick responses guys this forum is the best
PYR8_K1NG
Feb 26, 2024 07:05 AM
joekluger
Dec 14, 2023 02:05 PM
risctaker
Nov 20, 2023 07:20 AM
bullittandy
Sep 8, 2016 02:31 PM
edsterp
Jun 3, 2010 11:26 PM
