tune up
Old Aug 17, 2009 | 06:19 PM
lcyoung's Avatar
Default tune up
hello i got a 2002 jaguar xkr... im about to do a tune up on it.. n i was trying to find out is it difficult to change d spark plugs.. n can anyone give me the step to changing them out... like d proper tool.. the o.e. spark plug... and is there any thing extra i will need to change them out
Old Aug 17, 2009 | 06:40 PM
Usdm-sti-ftw's Avatar
Pretty straight forward stuff... Pop the ignition coil cover off the valve cover, unplug coils, remove 8 bolts which hold the coils in place, remove coils, remove spark and re-install in reverse order. Go to the dealer and get the factory specific plugs. They're expensive though, $25/each, they are just platinum plugs from what I understand and other co's have an OEM equivalent for a fraction of the price. Some people use NGK Iridium plugs without problem as well. I tried the OEM equivalent of Bosch's Platinum+ plugs ($4.99/each) and seem to work just ok, cold start idle is a little rougher than usual but once they warm up everything seem to be back to normal.
Old Aug 17, 2009 | 06:49 PM
remosusa's Avatar
Use the factory recomended plug.... you don't have to get them from the dealer, but use them.
I bought some top dollar name brand platinums and got bit by the cold start flooding issue twice... (even though they cross reference as being equivalent but "better" double platinum...etc)
XK8s are very well known for cold start flooding....
Old Aug 17, 2009 | 08:24 PM
lcyoung's Avatar
so i dont have to buy no valve cover gasket or anything n etc
Old Aug 17, 2009 | 08:35 PM
daddyo007's Avatar
Just did plugs and coil packs. I used ngk iridium about 7.99 ea. No problems.
I also used anti seize on plugs as well as dielectric grease on all electrical connections. Use a flash light to shine light into the plug well to be sure there is no debree, i can't spell tonight. I had oil in two of mine which were on the same bank. I used a paper towel to soak up the oil. Then I used compressed air to blow out the well before I removed the plug. Finding the oil led me to needing a valve cover gasket set, for the right bank. Carquest for about $75.00. I got them from my jag dealer for $94.00. Their set included the valve gasket 1, plugwell gaskets 4, bolt gaskets 2, and a seal for the cam sensor 1.
But I needed to ask them to match or get close to the Car Quest price. Also if you do need to get your covers off you will need a 10mm universal 1/4" drive socket for one specific bolt, Sears Craftsman about 8.00. The bottom bolt at the firewall is not accessable without this socket.
CAUTION: DO NOT ROTATE THE VALVE COVER OVER THE ENGINE THE GASKET IS WHAT HOLDS THE BOLTS TO THE COVER. THE HEAD IS FULL OF HOLES THAT WILL EASILY SWALLOW THEM. JUST PULL STRAIGHT UP. THE BOLTS WILL STAY IN PLACE WITH THE COVER. AGAIN BECAUSE THE GASKET HOLDS THEM IN PLACE.
Old Aug 17, 2009 | 10:02 PM
JagtechOhio's Avatar
I can sell you the Jaguar factory gasket and seals for $75.00 per side anytime.
Old Aug 18, 2009 | 04:35 PM
hlgeorge's Avatar
I replaced my plugs with the NGK Iridium IX #BKR6EIX and it made a big difference in operating smoothness. Found them at Auto Parts Place for $7.32 ea.
Old Aug 19, 2009 | 09:20 PM
daddyo007's Avatar
I'll keep you in mind, jagtech, when I get the kohones to tackle the tensioners.
Old Aug 21, 2009 | 01:23 AM
lcyoung's Avatar
thanks you guys this was easier than tuning up my mustang
MrWhite
19
Jun 14, 2022 07:49 PM
sdelliott58
Oct 1, 2015 01:46 AM
XJRick
Sep 28, 2015 02:12 AM
Woznaldo
Sep 26, 2015 11:02 AM
