Turns over but will not start
Old Jan 1, 2017 | 12:52 PM
daddyo's Avatar
Default Turns over but will not start
2002 XK8 battery went dead re charged car turns over but will not start. can hear fuel pump running. I had a site that explained how to reprogram key to ignition did it before and it worked the remote works fine. something with inserting key in door then turning then putting into ignition switch. anybody have any Ideas
Old Jan 1, 2017 | 01:06 PM
Welcome to the forum David,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Jan 1, 2017 | 01:15 PM
daddyo's Avatar
Old Jan 1, 2017 | 01:42 PM
grantorino62's Avatar
Do a fuel pressure test, if OK verify spark at a spark plug, post back.
Old Jan 1, 2017 | 03:38 PM
JagV8's Avatar
Bore wash?
(Probably not the key/programming.)
Old Jan 1, 2017 | 04:12 PM
StuG's Avatar
Just guessing, but I'm going to say that one of the fuel pumps has stopped working. Go to: https://www.jaguarforums.com/forum/x...torage-161879/
Post #2 explains how to check for fuel supply.
Cheers,
Stu
Old Jan 1, 2017 | 08:17 PM
daddyo's Avatar
fuel coming out of fuel rail has spark do you know how to reprogram ignition to key. as stated before when I did it it started just do not know sequence found a link but lost info
Old Jan 2, 2017 | 03:30 AM
JagV8's Avatar
OE jag tool. But it won't have lost the programming.
Old Jan 2, 2017 | 09:45 AM
WhiteXKR's Avatar
I think you are following the wrong trail. If the car turns over and has fuel I do not think you have a security or key issue.
On earlier engines (the AJ26) this could be a bore wash issue (search the forum for information) but it is less likely on your AJ27 engine.
Did you try to jump the car before you recharged the battery with the other car running? It is possible one of the engine management fuses has blown. Check the fuses in the small fusebox under the black plastic cover near the windshield on the passenger side (Left hand drive cars).
