Unique Head Bolt Pattern?
Old Mar 14, 2018 | 01:52 PM
jobagadonuts's Avatar
Default Unique Head Bolt Pattern?
Hello All,
I'm in the middle of a head gasket R/R and ordered a new set of head bolts that appear to have a unique head/cap design that requires a special tool?
Old Mar 14, 2018 | 02:03 PM
Jon89's Avatar
Looks like it takes some sort of a spline socket. I purchased a 7-piece metric set to fit my 3/8-inch-drive socket wrench at Harbor Freight last year. My set starts at 10mm and goes up to 19mm. Probably paid less than $10 for the set using a coupon....
Take your photo with you to the store so you can match it up to the proper tool. Better yet, bring those parts along with you....
Old Mar 14, 2018 | 02:10 PM
Gus's Avatar
Gus
Torque values or the size tool?
fmertz's Avatar
Looks like a VW/Audi Polydrive to me. Did not know Jaguar used those...
Old Mar 14, 2018 | 02:14 PM
oh, boy. Hope these are the correct ones! They are made by Eurospare.
Old Mar 14, 2018 | 02:27 PM
Old Mar 14, 2018 | 02:41 PM
fmertz's Avatar
You need to look at the specifics. These bolts could be recessed pretty low into the head and these short bulky bits won't reach. Check eBay for pictures of the VW/Audi Polydrive that show the long stem. FWIW, my understanding is that VW calls this 10mm tool "Polydrive", but it is part of a larger set called RIBE...
This is a nice bit, very stable, very confidence inspiring. Last thing you need is a stripped head bolt.
Old Mar 14, 2018 | 03:59 PM
motorcarman's Avatar
Yes VW started using those for the 1.8 turbo engines in New Beetles, Jettas and Passats.
Jaguar issued the RIBE bits to the Jaguar Dealers as SPECIAL TOOLS in 2003.
Cam sprocket and head bolts use this tool.
bob
Old Mar 15, 2018 | 07:35 AM
fmertz's Avatar
So, (confusingly?), this document refers to a 12mm short RIBE bit. Can it be used for the head bolts, or are head bolts supposed to be the smaller 10mm "Polydrive"? Most "polydrive" bits for VW/Audi on eBay refer to it as M10 (Metric 10mm?).
iamitltproof
Oct 15, 2019 07:42 PM
woodpuppy
XJ40 ( XJ81 )
Feb 6, 2009 09:44 PM
wayne1991
Jan 29, 2009 02:03 AM
vexred
Feb 18, 2008 09:38 AM
