Unknown device on XK8 Convertible 1997
Old Feb 23, 2014 | 08:10 PM
glbracke's Avatar
Default Unknown device on XK8 Convertible 1997
Hello everyone. I have a curious item in my 97 XK8 convertible. I have small 2 inch square speaker grilles on the dash on the left and the right side of my steering wheel. There is a 3 way switch to the right of the right grille with a volume control in the center of it. When I turn it on left or right, (the center detent is off) there is a little red light on my speedometer at the top of the 45mph and 135mph area. This is definitely factory done as the grilles are part of the dash and the lights are in the speedometer. When the key is on and the switch is to the left or to the right, the start up is a bird like chirping on the left speaker with the left light (the one at 45mph) blinks, then the right chirps and the 135mph light blinks. The lights and chirps will go off without any warning while driving. I can't make heads or tails to what this device is. Nothing in the manual. Any help?
Attached Thumbnails Unknown device on XK8 Convertible 1997-kimg0102.jpg   Unknown device on XK8 Convertible 1997-kimg0103.jpg   Unknown device on XK8 Convertible 1997-kimg0106.jpg
Old Feb 23, 2014 | 09:12 PM
Steve8's Avatar
Welcome to the forum.
My guess is that you have a radar detector installed on your cat. There was someone else with lamps carefully installed in the gauges, although I don't recall a description of the sounds.
Post some pictures?
Steve
Old Feb 23, 2014 | 11:07 PM
Dr. D's Avatar
Howdy folks:
Sounds like another stealth K40 Radar detector similar to mine. Had I installed it, I too would opt to put the leds in the instrument panel for that factory look instead of the bezel.
Here is a link to the old post which contain my comments. >>> https://www.jaguarforums.com/forum/x...at-they-61503/
PS Don't get caught with it on in VA.
Old Feb 24, 2014 | 02:34 AM
Originally Posted by glbracke
......... This is definitely factory done as the grilles are part of the dash and the lights are in the speedometer. .....
I would disagree. It may be neatly done but it is definitely not an OE factory fitting on the XK8.
Old Feb 25, 2014 | 11:28 AM
glbracke's Avatar
Default Added pictures
I have added the pictures of the system. The little lights on the speedometer above the 45mph and 135mph. The little speaker grilles are definitely molded to the dash. They aren't added on. Hope this helps.
Old Feb 25, 2014 | 11:39 AM
RCSign's Avatar
Gilbert
The grilles are standard fare for all XK-8's, the switch is not, the factory wouldn't add a switch like that, it would match the other rocker type switches. The lights I couldn't tell you about.
Old Feb 25, 2014 | 12:27 PM
Dr. D's Avatar
Still looks like a K40 to me.
Try this link >>
http://www.k40.com/filebin/pdf/1000_2000_INSTALL.pdf
(Also look on the front bumper / grille area for the FRONT RADAR RECEIVER)
I agree that the little grilles are factory and that the inboard one is for the factory aspirator fan. Hope this helps
Old Feb 25, 2014 | 02:01 PM
The grille arrowed in red is for the In Car Aspirator (part of the A/C system) and the one arrowed in blue is to allow the sound of the small speaker for the warning buzzer to be audible.
These are standard OE Jaguar fittings.
The switch is not OE and, as others have suggested, is likely to be part of an aftermarket radar detector installation.
Old Feb 25, 2014 | 05:09 PM
Mr. Feathers's Avatar
That's a K40 radar detection system. I wish my car came with one thrown in... they cost $$$$
Old Apr 25, 2014 | 06:30 PM
glbracke's Avatar
Thanks everyone for the information. I do believe it's a K40. There's a shop no far from here and I'll take it down to have them check it out.
Old Apr 28, 2014 | 02:29 PM
If you decide to have it removed, I would be interested in purchasing.
99xk8guy
Sep 29, 2025 10:51 PM
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
mrplow58
Jan 21, 2024 05:53 AM
speacock
Sep 14, 2015 07:57 PM
