Unknown and missing
Old Sep 6, 2023 | 06:48 PM
BLKLSTD's Avatar
Default Unknown and missing
On my 2000 xkr convertible there are two connectors, 12 pin and 16pin, in my trunk. Looks like would be for a module. It would have mounted to the left rear of spare tire. Anyone know what these would have connected to. I've only found a 97 manual. It and everything I've found doesn't have anything there. Please and thank you.
Circled in red
Old Sep 6, 2023 | 07:11 PM
NorXKR's Avatar
That is for the telephone control module I think
Old Sep 6, 2023 | 08:10 PM
motorcarman's Avatar
The cars were built for a WORLD MARKET and not every Country has things that are allowed or the market was designed for.
There will be connectors dangling with no apparent function or connection.(Jaguar put these connectors in the harness JUST TO **** YOU OFF)(sarcasm)
Old Sep 7, 2023 | 09:29 AM
BLKLSTD's Avatar
Maybe they just wanted to sell us a couple more connectors, and some wire, weather we needed them or not.
Whatever the reason, sometimes you need to know what you're working with. It appears I've got an open circuit somewhere in the canbus circuit
Old Sep 7, 2023 | 09:31 AM
BLKLSTD's Avatar
Thank you. I think you are correct.
Old Sep 7, 2023 | 10:00 AM
I would suggest that you take a picture of the VCATS label so you have that info if you ever need a replacement module.
Old Sep 7, 2023 | 12:37 PM
BLKLSTD's Avatar
Do they tend to be a problem? I was getting error messages for that, along with abs and traction control. After cleaning the wheel speed sensors, they seem to have gone away. Might have had the dampening message, not sure. Have to get it a bit more road worth. RF tire developed a lump. I've got new tires and a wheel to replace a cracked one supposed to be here today. Then you I'll be replacing the front crossmember mounts and whatever else I find adding to the inside edge wear. Then I'll get back to the electrical issues. Hopefully sometime soon I'll get to putting some new paint on it. I knew Jaguar parts aren't cheap. But I had no idea it was the paint too. Something like $800.00 a gallon. That's insane. It'll get new paint and it'll look about the same. It won't be an actual Jaguar color though. After that I think I'll just be left with the hoses for the convertible top.
Old Sep 8, 2023 | 07:58 AM
dibbit's Avatar
The telephone module is behind the rear seat cushion. Those wires are for the reverse park sensor module -which is missing in the photo.
Old Sep 10, 2023 | 02:30 PM
michaelh's Avatar
Too many connections for the parking aid module. JTIS shows its location rear LHS of boot/trunk.
...but only for MY2000
Old Sep 11, 2023 | 01:11 PM
for paint - try this place for half the cost Choose Your Paint Size | AutomotiveTouchup
LastPlace
Jul 10, 2022 11:09 AM
dag82
Oct 20, 2020 06:42 AM
Red
Sep 23, 2020 06:50 AM
Buzzer
May 23, 2020 07:51 PM
MTypeX
Nov 28, 2018 01:33 PM
