Unseated an injector - now it's leaking
Old Apr 6, 2012 | 01:59 PM
dx3's Avatar
dx3
Default Unseated an injector - now it's leaking
Gentleman,
When I was pulling the valve cover etc off to do the upper tenisoners I wasn't paying attention and accidentally unseated one of the injectors when not watching what I was taking off (the half circle injector metal clamp things). I tried to reseat it by pushing it in and then putting the metal clamp thing back on it and tightening it back down. For some reason it didn't seat properly and was leaking. I tried again and sill no luck. Is there a secret to getting it to seat correctly? Or might I have damaged an o'ring? Any advice or assistance would be much appreciated.
Old Apr 6, 2012 | 03:32 PM
Mountaincat's Avatar
Most injectors have "O" rings on both ends. You normally have to replace the ring and then lube it up with oil to slide it back into place with a side to side rocking motion.
Old Apr 6, 2012 | 10:24 PM
dx3's Avatar
dx3
Pulled it out and it had a failed Oring. Fixed it and we are back in business Thank you for your response sir.
ogorir
Jan 18, 2016 10:09 PM
Jagged-X
Sep 24, 2015 05:08 PM
arskemp
Sep 21, 2015 02:19 PM
Tim Goz
Sep 17, 2015 09:11 AM
Bcrary3
Sep 11, 2015 10:36 AM
