Upgraded transmission pressure regulator results?
Old Feb 12, 2019 | 10:02 AM
Ophitoxaemia's Avatar
Default Upgraded transmission pressure regulator results?
Can anyone report on the longer term effect of installing, in my case, the CT powertrain products part 5HP-24-PR transmission kit?
Local shops won't touch my transmission until after it grenades, and I wanted to see if this kit is worth installing.
My symptoms are the occasional clunk starting from a near stop, and slow to switch between forward and reverse when hot.
2000 NA Coupe, 101K miles. The transmission had a $4K service by the previous owner, 20-30K miles ago.
Old Feb 12, 2019 | 10:43 AM
CorStevens's Avatar
what kind of service costs $4K? would not install a kit unless and until you can discover what is your current problem. suggest that you find one of the actual ZF centers near you and have them diagnose the problem. if it is fixable, i strongly suggest installing the upgraded A-drum as part of any work involving removal of the transmission.
Old Feb 12, 2019 | 11:40 AM
He said it was rebuilt because "it was slipping". But what I suspect happened is it will slip if the fluid is low (foams?), and they "fixed" his transmission by refilling it.
What is a "ZF center" and how do I find one?
So far, the only work I can get anyone to quote me on is a $5200 rebuilt swap. If I can extend the life of the current one, I think it makes sense but I can't find anyone that is interested. One shop said to wait until it blows up, then use a cell phone and a tow truck. Do not like.
Old Feb 12, 2019 | 11:56 AM
Jon89's Avatar
Call ZF tech support in Chicago and discuss your situation with them. The number is (800) 451-2595. Ask for Steve Jaffe or Joe Laubinger. Both of them have given me great advice over the years on our 6HP26 transmissions. They may be able to refer you to a local ZF shop....
Old Feb 12, 2019 | 12:08 PM
CorStevens's Avatar
obtain the contact information for the shop that did the service; there are too many unknowns. ZF has authorized service centers. a simple google search helps here. ask an independent Jaguar mechanic about which transmission shops he uses.
Old Feb 12, 2019 | 06:20 PM
Thanks for the info. I called ZF Chicago and talked to Joe. He was very informative, and that info was helpful when I was talking to a shop.
Joe told me slow shifting or clunk on start from stopped could be pressure regulator or solenoids. But when I said it was worse when it was hot, it was likely a leak.
Now I'm trying to figure out if the shop I have an appointment at is going to try to soak me.
Old Feb 12, 2019 | 06:43 PM
CorStevens's Avatar
my little rule of thumb: if you have any concern that a shop will take advantage of you, do not go there. in a big car culture state there should be many trusted and competent shops. try something like Yelp or ask a trusted Jaguar specialist shop for a referral.
Old Feb 12, 2019 | 07:14 PM
What's been happening around here is shops with a good reputation being sold and then run into the ground, living on the reputation. Or going out of business. Or refusing to do work that's too small or might be tricky. My nearest Jaguar shop won't return calls.
I had a rebuild done on my truck transmission last year (radiator leaked into the cooler) and I think I was their only customer, lot was empty. Everybody is driving Teslas and leased Mercedes' these days.
Old Feb 12, 2019 | 07:30 PM
CorStevens's Avatar
yep, the leasing craze in the coastal markets really changed things for the established businesses. happened where i live. still, if you look around including searching the regional sections here, there are places to go. ZF has authorized service centers. check their website for a list.
Old Feb 12, 2019 | 08:07 PM
CorStevens's Avatar
try these folks, my independent hears good things about them: www.eurotransspecialists.com
Old Feb 12, 2019 | 08:45 PM
CorStevens's Avatar
just got this referral from a friend. yes, he is a BMW specialist but knows and services the ZF 5HP24.
https://sandiegobmwrepair.com/auto-s...mission-fluid/
Old Feb 12, 2019 | 10:18 PM
Thanks! Those are both So Cal, 400+ miles from me. But I have a lot more info and have a shot at getting something useful done!
Old Feb 13, 2019 | 05:47 AM
CorStevens's Avatar
welcome, this is why flatbed transporters were invented. spend a small bit more time and money and be done. do it right or do it again.
Old Feb 13, 2019 | 10:28 AM
Flatbed is $11/mile!
Old Feb 13, 2019 | 03:47 PM
RJ237's Avatar
I'm sure there are members in the bay area who can recommend a shop. Try posting in the regional and XJ8 (x308) forums.
Old Feb 14, 2019 | 10:36 AM
CorStevens's Avatar
wow, the cost of living is much higher there. well you could probably rent a truck with a flatbed car trailer for much less. i've done this and it went well. there is always a creative solution.
Old Feb 14, 2019 | 11:49 AM
I once reserved a U-haul car trailer a couple weeks in advance. I go to pick it up and they say they don't have one. "One didn't come in" they shrugged. Never tried again.
I think when the A-drum goes, the car will still reverse. So I could load it that way, if I could get a trailer. Already have a truck.
Old Feb 16, 2019 | 11:39 AM
DavidYau's Avatar
Default Back to original thread topic - CT Powertrain ZF5HP24 upgrades
hi, on another thread i’ve been considering a renewal/overhaul of my tranny over summer 2019. Looking at the website, i’m not sure installing the CT Powertrain kit is worth all the effort of removing the tranny out of the car.
My thoughts relate to getting the valve body serviced, but i’m Struggling too to find someone willing to take it on. My only choice today in Bahrain is to change sump filter and fitting the transco upgraded pressure valve. When I ask if they can do an A Drum install or D/G clutch work, garages doesn’t want to know
EZDriver
Sep 29, 2014 04:24 PM
car5car
May 20, 2014 10:15 AM
Skid Mark
Feb 5, 2013 10:22 PM
Keltam
May 27, 2009 08:25 PM
beeturbo
Jun 16, 2008 02:03 AM
