US import XKR 4.2 no keys
Old Mar 12, 2026 | 01:44 PM
dutchviking's Avatar
Default US import XKR 4.2 no keys
Trying to help a friend who imported a XKR from the US from a car sales place that went bankrupt (or something like that) and in anger the owner threw away all the keys of all vehicles he had there (or so the story that was told to my friend). He bought a new key in the US and one here in Norway. One key has ID46 and the other one ID48. Problem is that he first gave the car to a Land Rover Jaguar workshop that removed half the dashboard, then gave up on the car. We found that several modules had been removed and some seemed to have been opened. I am using SDD v130 downloaded from the jaguarforum.com with a good working Mongoose. I tried it on my own Discovery 3 and in Engineering mode changed something in the CFF, and everything works just fine, making me think the diagnostic platform should be ok. However when trying to add one of these keys initially the SDD routine goes well, but then getting "Control module set-up procedure failed".
I also saw this message: Mismatch in control module programming
When I tried to run the Immobilizer routine it fails on a Testman error.
To check if all modules belonged to this car I did the Control module identification routine, all modules (I think) were showing, but the Key Transponder Module had a different part number than was shown on the module itself, which was LNF 2665, but not sure if this is a wrong thing. The last numbers of the VIN were there in the KTM in any case.
Does anyone have an idea what is wrong? Are both keys not correct and that throws these error messages? How to be sure that the KTM module is the original one, it is the only module showing a question mark after the diagnostic scan but there are no KTM faults to be read in the list with DTCs. Is the coil around the ignition barrel just a coil that when energized makes sure the code from the transponder chip in the key can be read and compared with stored codes? Both keys are real ignition keys, not Valet keys, and Ignition can be turned on with both, but obviously starting is not possible since a key is not coded to this car. Any help is much appreciated.
Old Mar 12, 2026 | 04:10 PM
michaelh's Avatar
"Control module set-up procedure failed". Welcome to the world of utterly useless error messages - not by any means confined to Jaguar software Yesterday's weather, anyone?
I'm almost at the same stage as you, looking at a late XKR that has been 'doctored', but I'm still learning my way around SDD. I can tell you that LNF2665AA is the correct KTM for the car.
The testman error means that SDD has crashed, AFAIK.
I can't talk to the KTM either:- I also get the question mark on the the vehicle scan, but there's a separate issue I'm still investigating which may or may not be the cause.
Take a look at this thread from norfskate regarding the keys:
https://www.jaguarforums.com/forum/x...1/#post2006133
AN unrecognised key will usually throw a P1260 code.
VIN A47483 is MY2005, and around 1000 cars from the end of production.
Last edited by michaelh; Mar 12, 2026 at 04:19 PM. Reason: correct VIN & P1260 add
Old Mar 12, 2026 | 04:35 PM
Thanks for taking the time.. Someone told the owner (my friend) that the EEPROM inside the KTM can be updated with the transponder code of the ID48 key? I have done such coding with a Range Rover Sport L320 once where both keys were missing. Coded the transponder chip code to the BCM, then the car allowed coding 2 keys to it. Not sure about this Jaguar. Theoretically SDD 130 should be fit for this job, correct? I tried with my original Rotunda VCM from back in the days but although SDD said the VCM was connected it could not read the VIN and gave me XXXX. When entering the VIN manually it came to 98% of the module scan, then stayed there forever. Tried with SDD 162 and an official Diagnostics Associated JLR VCI (Jaguar Land Rover Approved SAE J2534 Pass-Thru Interface) for SDD but got same error messages as in my first post, confirming that the Mongoose and SDD 130 are working ok and that it is the car/modules not cooperating.
Old Mar 12, 2026 | 05:12 PM
michaelh's Avatar
That is my understanding of the 'Immobilisation setup' process, and up to 5 keys can be programmed. I am using V130 (with clone Mongoose) which will happily read the VIN. I wonder why SDD responds with the question mark when it's clearly able to read your KTM?
edit: I'm wrong here. 'Program new transponder' is the process for adding keys, not immo setup.
For me, SDD does take quite a while between 98% and complete. It did stick there once, but that was because I'd not turned the ignition on
I've attached a TSB re the VID block stuff related to the 4.2L. It may be of use if you believe that someone may have been swopping modules around. It's targeted at WDS but valid for IDS/SDD.
Old Apr 21, 2026 | 09:27 AM
harencguri's Avatar
hello , i have the same problem... i have buy a jaguar xk8 year 2005 with no key... i try to learn key but it show me : mismatch in control module programming ... i try also with transpoder id13 also with id48... have you solve the problem ?!
Old Apr 21, 2026 | 10:10 AM
I removed the 93LC46B from the Key Transponder Module and read its code with VVDI. Asked my friend the Locksmith but he could unfortunately not do much with the file. However, I have learnt that TMPro2 with Jaguar Immobox SW50 can read the KTM EEPROM and write 2 new transponders to it, which should be able to start the car. I bought the kit today, will be back here after I have tried this option.
Old Apr 21, 2026 | 10:12 AM
Old Apr 21, 2026 | 10:21 AM
michaelh's Avatar
What tool are you using - Jaguar IDS/SDD or some other?
Old Apr 21, 2026 | 10:23 AM
harencguri's Avatar
i am using LAUNCH also AUTEL ... still the same problem
Old Apr 21, 2026 | 10:39 AM
michaelh's Avatar
Launch should be able to to it, AFAIK. I don't know the Autel. Is it possible someone else has been involved before you got the car?
ID13 key is definitely not for MY2000-on.
Old Apr 21, 2026 | 10:43 AM
harencguri's Avatar
yes right, i have id48 as mine is year 2005... it might be corrupted the eeprom 93c46 of immo box because vin number it show FFFFF ?!
Old Apr 21, 2026 | 10:51 AM
I was able to read the 93LC46B EEPROM and asked my Locksmith friend to check the file. However he was nit able to use it. I then learnt that TPMPro2 apparently is THE TOOL to use for these older Jaguars. I have ordered the full kit today with new transponders, if the tool does what it is supposed to do I will soon be able to code 2 new transponder chips to the Key Transponder Module (the 93LC46B EEPROM) and let you know the result.
Old Apr 21, 2026 | 11:00 AM
michaelh's Avatar
I see that your tool also reports a different part # for the KTM. LNF2665AA is what will be printed on its label, although it is the correct part # for the car. Is it the original one, or possibly a new unprogrammed unit (which might explain the 0xFF bytes)?
Haven't seen dutchviking around since this thread, so no idea if he solved his.
Old Apr 21, 2026 | 11:05 AM
harencguri's Avatar
LNF2665AA yes this is label printed .... no its original car ... but i am not sure if anyone before me has try to play with module and make this byte of vin FFFFF... i have read eeprom 93c46 but doenst understend where is bytes of VIN...
Old Apr 21, 2026 | 11:17 AM
michaelh's Avatar
It was just a thought as the car would obviously be worth more if running. I pulled the eeprom out of the water-damaged module, but there was very little info in there. An SDD trace file showed tha the VIN could possibly be stored there, although it wasn't...
ncanales33
Oct 15, 2024 12:27 PM
willbot
Nov 6, 2023 03:33 AM
sonicspeedway
Feb 13, 2023 07:48 AM
Terryble
Oct 15, 2022 03:05 AM
brett1930
Apr 10, 2020 03:15 AM
