Vacuum Leak Throttle body elbow? 2000 XK8
Old Aug 10, 2014 | 08:31 AM
AP3's Avatar
AP3
Default Vacuum Leak Throttle body elbow? 2000 XK8
2000 XK8
Plastic tube coming off the elbow with the heat shield sleeve is broken. I am told by Jaguar that I need the entire elbow and plastic hose to replace just the plastic hose. The hose is damaged at the stem where it goes into the elbow. Any idea how I can replace this hose without replacing the entire elbow?
Thanks,
Attached Thumbnails Vacuum Leak Throttle body elbow? 2000 XK8-imag2267.jpg   Vacuum Leak Throttle body elbow? 2000 XK8-imag2268.jpg
Old Aug 10, 2014 | 06:39 PM
britannia's Avatar
Wrong forum..........but my wife has a 2000xk8; I don't recognise the part...........are you talking about maybe the round intake plenum between air cleaner and throttle body ? which has a small plastic pipe for valve cover breather with an elbow? or what
A pic would really help XK8 owners.................
Adrian
Old Aug 10, 2014 | 06:43 PM
AP3 - I've moved your post from the XK/XKR to the XK8/XKR section where members with the same model will be able to assist.
regards,
steve
Old Aug 10, 2014 | 06:55 PM
ccfulton's Avatar
Is there enough usable that you could cut it off and use a barb fitting with a new piece of hose?
Baring that, you could drill out the plastic form the elbow and epoxy in a new fitting of any type you like.
Old Aug 11, 2014 | 01:26 PM
Rezzz's Avatar
Originally Posted by AP3
2000 XK8
Thanks,
I just bough this one Jaguar X100 Air Vacuum Hose Line w Heat Shield | eBay. I broke the end off mine and in case it is not long enough I picked this one up. I'll check mine out on this weekend and if it works I will sell you this one plus the shipping to route it to you if your interested.
Old Aug 11, 2014 | 09:00 PM
Gus's Avatar
Gus
I repaired my plastic vacuum line on my 99xk8 and from what I can see you are talking about the same line. Look at the last few photos on my pipe repair and see if it is the same one.
Old Aug 12, 2014 | 02:08 PM
AP3's Avatar
AP3
I am definitely interested. Msg me 678-794-3725
toronadomike
Jan 22, 2026 10:13 PM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
Xkr x100
Sep 6, 2015 08:50 AM
