View your build sheet/ options in your XK8
Old Mar 31, 2016 | 01:21 PM
zidjan's Avatar
Default View your build sheet/ options in your XK8
Hi folks,
Just an FYI..I just found a way we can look at our cars build sheet by going to this ford website..this is probably been posted here before but just in case those that don't know, here it is... enjoy!
FordEtis home page
Old Mar 31, 2016 | 04:40 PM
cyber3d's Avatar
That's pretty darn cool.
Old Mar 31, 2016 | 04:43 PM
DaveInVA's Avatar
Doesn't like mine:
"We are sorry, but no information could be found for the VIN/Registration number you entered"
Dave
Old Mar 31, 2016 | 06:02 PM
sweez's Avatar
Mine didn't work either
Old Mar 31, 2016 | 08:30 PM
johns55's Avatar
Mine worked fine. I wonder what causes some to work and others not to.
Old Mar 31, 2016 | 09:49 PM
rperformance's Avatar
Worked for my 04 where the dealer system rejects the vin number. There is a note on Fords page showing RECENT vin numbers, so there must be a cut off date.
Old Mar 31, 2016 | 11:22 PM
Johnken's Avatar
Does not work for my 98.
Old Apr 1, 2016 | 07:46 AM
worrasf's Avatar
Originally Posted by zidjan
Hi folks,
FordEtis home page
Thanks - that's so helpful. Seems mine is missing it's factory fitted first aid kit
Steve
Old Apr 1, 2016 | 08:00 AM
VinceCh's Avatar
It didn't show mine either, but I wasn't surprised. My Jaguar Heritage certificate says that the build date for my car is "Not Recorded". How can I expect Ford to know these things if Jaguar doesn't?
But thanks anyway to zidjan for making this site known. I'm sure it can help owners of newer Jags than mine.
Vince
Old Apr 1, 2016 | 08:01 AM
daro31's Avatar
Default Thanks, great tool
It worked great for m 2004, now I know my ladies birthday. Have to do something nice for her Oct. 17th.
reb1999's Avatar
First aide kit only to 1st owners over 6 foot in height. Kit comes with a head as well as knee bandage. Rich
Old Apr 1, 2016 | 08:03 AM
michaelh's Avatar
Used it a few days ago to get basic info on 434Mhz's 96. I've not had a fail yet with either US or EU samples. Must just be lucky, I guess, although I've seen more than one instance where the reg. documents are wrong. Mine records a 'D' that is really a zero..
There's not much info on the early VINs, but becomes more informative from 1999 onwards.
M
Old Apr 1, 2016 | 08:36 AM
kstevusa's Avatar
Worked OK for info on my 2003.
Old Apr 1, 2016 | 09:59 AM
MRomanik's Avatar
Veteran: Air Force
Didn't work for my '97.
Old Apr 1, 2016 | 10:44 AM
zidjan's Avatar
Woow...looks like it worked for MY2003+ but not older? when does Ford took over Jaguar??
Jandreu's Avatar
Thanks for the link, very nice.
Mine say's it's a Series 25???
Lists a Leather Gear Shift knob which I don't have, also list "Less Anti-Spin Traction Control" this is strange as I do have traction control.
File Type: pdf
Old Apr 1, 2016 | 06:45 PM
Rick L's Avatar
Worked for my 2001.
Old Apr 1, 2016 | 07:34 PM
K.Westra's Avatar
Code:
Build Date:	  08.02.2000
Vehicle Line:	  Jaguar X100
Body Style:	  Cabriolet
Version:	  Series 20
Engine:      	  JAG-4.0L DOHC EFI NA V8 GAS
Transmission:	  5 Speed Auto Trans ZF 5HP24
Drive:	          LHD RWD
Axle Ratio:	  3.06 Final Drive Ratio
Emission:	  LEV Requirements
Air Conditioning: Automatic Air Conditioning
Territory:	  (+)"USA"
Minor Features
 Marketing Level 1
 Less Warning Display
 Less Heated Windscreen
 With Console Cup Holder
 Less IP Facia Monotone Colors
 With Electrochromic R/View Mirror
 Cabriolet
 Dual Power/Heated/Memory Mirrors
 1 Flat / 1 1400MM Convex - NAS
 With LH Electric Lumbar Support
 With RH Electric Lumbar Support
 With Drivers Heated Seat
 With Heated Passenger Seat
 With Driver 6 Way Pwr.Seat Adjuster
 With Pass 4 Way Power Seat Adjuster
 With Programmable Driver Seat
 315 MHZ Door Lock Frequency
 With Automatic Windscreen Wiper
 With Headlamp Washer
 Less Isofix Hard Point Attach
 Limited Service Mini Spare Tyre
 With Performance Suspension
 Less Handling Package
 With Catalyst
 With Anti-Spin Traction System
 With Onboard Vapour Recovery System
 With 95 Octane Level Petrol
 Fuel Tank Filler Neck - Unleaded
 With Power Tilt Tele Memory Column
 With Speed Control
 Less Navigation System
 Less Reverse Proximity Sensor
 Less Engine Immobiliser
 With Safeguard Anti-Theft Sys(Pats)
 With CD Player Autochanger
 Premium (+) Sound With CD
 With 8 Speakers
 Less Telephone Preparation Pack
 With Garage Door Opener
 With High Mounted Stop Lamp
 With Automatic Headlamp On/Off
 Jaguar X100
 Series 20
Old Apr 2, 2016 | 03:04 AM
The FordEtis website data appears to be less detailed than Jaguar's Direct Dealer Warranty System data.
Using the VIN for my last 2005 XK8 4.2 S Coupe ( VIN SAJAC41P362A47779 ) as a test, FordEtis returns more generic results for the options level details.
Here's the Direct Dealer Warranty System data:
View your build sheet/ options in your XK8-01-specification-xk8-4.2s.jpg
View your build sheet/ options in your XK8-02-specification-xk8-4.2s.jpg
View your build sheet/ options in your XK8-03-specification-xk8-4.2s.jpg
View your build sheet/ options in your XK8-04-specification-xk8-4.2s.jpg
(click on the images to enlarge them)
Anyone can check this equivalent FordEtis output using my VIN.
View your build sheet/ options in your XK8-fordetis.jpg
FordEtis is a useful tool but I'd go with the Direct Dealer Warranty System printout where available.
Old Apr 2, 2016 | 11:56 AM
Johnken's Avatar
Graham, Could you tell us where access to this Direct Dealer Warranty System is located? A www search just brings up all sorts of extended warranty companies. Is this something one can view outside the dealership?
Thanks,
John
