Wax on key over Jaguar face??
Old Sep 6, 2021 | 01:35 PM
Markmbaha1's Avatar
Default Wax on key over Jaguar face??
Previous owner covered the Jaguar face in the middle of the key with what appears to be wax, see attached. Anyone ever seen this and or have a suggestion how to ckean it off?
thank you so much!!!
Mark
Old Sep 6, 2021 | 01:47 PM
kstevusa's Avatar
Appears similar to the film that some have on the trunk button that opens the boot. Some say rubbing alcohol cleans it, but I used a Plastic polish to clean my button. Perhaps it would also work on the key. Maybe an abrasive toothpaste would also work.
Old Sep 6, 2021 | 03:20 PM
Jon89's Avatar
Rubbing alcohol indeed cleans up the trunk button (at least temporarily). I would try it on your key as well....
Old Sep 6, 2021 | 03:36 PM
Markmbaha1's Avatar
I saw someone else replied has the same substance over the growler. Is this normal?
Old Sep 7, 2021 | 02:16 AM
dibbit's Avatar
I think it is just the plastic itself deteriorating with age. I solved the problem on my keys by buying replacement emblems on ebay.
Old Sep 7, 2021 | 08:11 AM
Markmbaha1's Avatar
Does anyone have a picture of what that part of the key is supposed to look like new?
Old Aug 20, 2024 | 07:27 PM
pcroft51's Avatar
Jorge,
I had an over heating problem with non-operating electric fans. The temptation was to replace fans and radiator. Trying to keep the budget manageable I opted to replace both fans. With a cooling system flush and the new fans it runs just to to high side of "Normal". The available after market aluminum radiators will will help even more, but at $1,500 plus, I opted to start with the fans only--so far, so good.
You can make the carb conversion to make it more like a Series I car, but you're probably looking at $6,000 to $8,000 (parts only) for the triple SU carbs and manifold. May be more practical to get your baby running and sort out the absolute "Need To" items first, them think about the carburetor up-grade.
Phil
Old Aug 21, 2024 | 01:52 AM
dibbit's Avatar
Originally Posted by pcroft51
Jorge,
Phil
Another victim of the Related Thread forum feature.
Jaguarstyper
Sep 6, 2021 08:40 PM
Sovejag13190
Sep 22, 2018 05:46 AM
adpock
F-Pace (X761) / C-X17
Aug 22, 2016 09:22 PM
StuG
Australia - Queensland
Aug 27, 2015 01:13 AM
martyn812
Sep 26, 2011 07:14 PM
