What is it?
Old May 1, 2021 | 02:57 PM
Old Matelots's Avatar
Default What is it?
As part of my ongoing efforts to expand my X100 education, I have today two 'what is it' pics for the learned members of the Forum. While scrolling through the folder recording my recent front suspension refresh, I came across two images that puzzled me when I took them, but which I had subsequently forgotten about. The first is an elaborately sculpted chunk of foam that fell on the floor under the washer bottle as I was removing the driver side fender liner. I could see no obvious secure location for it, or any indication if it is an OEM cushion/anti chafe device between bumper cover and washer bottle or a piece of PO bodgery? As I couldn't decide where it went I left it out when I replaced the fender liner. The second pic shows an inverted hook shaped plastic clip, pushed into the the body sealing foam where the inner fender reinforcing panel meets the inner sill. Both sides of the car have a clip/hook in the same place. Possibly a harness retainer for some option my car doesn't have?
Mystery Foam Wedge
Mystery Hook/Clip
Old May 1, 2021 | 11:26 PM
DavidYau's Avatar
Default NOt worth worrying about
Old Matelots,
I too have seen both. For the form piece, from the shape of it, it seemed to me to go on the top front of the wheel well maybe to stop the thin liner flapping about. I did notice that there were no plastic fixings in this location. Also my foam piece had disintegrated in the heat, but one side was shiney so maybe there used to be glue on that side.
For the hook, they don’t seem to serve any purpose so maybe it was just a location fixture for factory fabrication when they fitted up the panels.
For both I don’t think they’re critical.
Old May 2, 2021 | 07:59 AM
SamtheSham's Avatar
They are both obviously "Thingamajigs".
Old May 2, 2021 | 09:08 AM
dfbender's Avatar
Only way to be sure would be to remove wheel on other side and then look to see if they are there too.
Greg in Tampa
Aug 3, 2025 03:59 PM
Brian8700
Dec 2, 2020 11:29 PM
Barry_Tucker
Oct 29, 2017 05:38 PM
julien4020
Jun 19, 2015 03:58 AM
Greg in France
Jun 7, 2013 01:56 PM
