What bolt pattern and offset, 20"x9"/10" XKR BBS Sepang
Old Nov 5, 2012 | 03:14 PM
xenophobe's Avatar
Default What bolt pattern and offset, 20"x9"/10" XKR BBS Sepang
I'm trying to get a replacement front wheel from some guy on ebay. He listed the identical part I needed, but after purchasing the item on ebay he's not sure what wheel I need, despite knowing that I have an 05 XKR and need the 20"x9" Sepang.
He wants to know bolt pattern and offset I guess... what numbers do I give him?
Sorry, I tried searching a few times and didn't come up with what I needed. :\
Old Nov 5, 2012 | 05:58 PM
It sounds like he may have the 20" Sepang off an XJ and is suddenly worried it doesn't fit the XKR.
I went after a replacement front Sepang for my XK8 and found the XJ 20" Sepang is different. Apparently it's a 49 mm and the XK is a 33 mm.
I have absolutely NO IDEA what this measurement means but hope it helps!
Old Nov 6, 2012 | 12:35 AM
xenophobe's Avatar
Ah ok, thanks! I'll see if that helps!
Old Nov 6, 2012 | 01:29 AM
Cambo's Avatar
The PCD is different too.
X350 Sepang = 9Jx20" all round, ET49, PCD 108x5
X100 Sepang = 9Jx20" front, ET25, 10Jx20" rear, ET25, PCD 120.65x5
Well that's according to my information, might be ET33?
You should see the PCD & ET info cast into the back of the spokes.
hunter34
19
Sep 14, 2022 11:09 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Matei Dima
Oct 8, 2015 11:45 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
ferraripete
Sep 10, 2015 01:24 AM
