The "What did you work on today" thread.
Old Jun 8, 2017 | 11:39 PM
  #241
prettybluefin's Avatar
Updated dash lighting (not difficult, but took me about an hour with all the parts that needed to be removed) & put Carbon Fiber around the shifter (probably will do entire dash soon) Gunmetal Grey
SO much more modern...
LOVED the wood, but didn't like it with the dark charcoal leather...
Old Jun 9, 2017 | 02:31 AM
  #242
Salo's Avatar
Originally Posted by chillyphilly
Got around to cleaning and dressing the engine bay this afternoon. Slowly getting her cleaned.
looks great, just like new !
Old Jun 9, 2017 | 05:20 PM
  #243
mhminnich's Avatar
Default A good morning
Adjusted the shift linkage to cure a gearbox selector fault, and while I had the console out, added the antenna kill switch. A good morning!
Old Jun 9, 2017 | 07:03 PM
  #244
dsd's Avatar
dsd
Went to a breaker and bought a pair of seats so I could steal the seat release trim. Mine is NED, these were AGD or SDZ, so I used SEM paint.
These will look good when we reupholster next week.
Attached Thumbnails The "What did you work on today" thread.-img_5406.jpg   The "What did you work on today" thread.-img_5407.jpg   The "What did you work on today" thread.-img_5408.jpg   The "What did you work on today" thread.-img_5413.jpg   The "What did you work on today" thread.-img_5420.jpg
Old Jun 10, 2017 | 09:01 PM
  #245
mhminnich's Avatar
Repaired one of the plugs for my front CATS shocks. That was a fiddly bit as the wires had broke flush at the top. I got the pins out of the connector, soldered in new leads, and now everything works again. No suspension errors!
Next up is the ABS module repair. Also looking for a solution to the Low Coolant warning (it's not).
Old Jun 11, 2017 | 12:00 PM
  #246
dsd's Avatar
dsd
Replaced all the bulbs in the center console (near the stereo).
Swapped the gear selector for a NOS one I found.
Was going to swap lighter with a new one but it's backordered.
Old Jun 11, 2017 | 05:57 PM
  #247
chillyphilly's Avatar
Ongoing cleaning...
Removed all four wheels to clean them, check brake pad wear, clean fender wells, etc. I used Meguiars APC 10:1 and a Scotch pad to clean a lot of the grime off the wheels. APC 10:1 and a fender brush cleaned the fender wells with a follow up of Meguiars 4:1 to dress them. I also used Rustoleum Aircraft Cleaner to strip the paint off the wheel bolt holes where someone had painted black and grey over the chrome. Good news is no peeling chrome behind it. It didn't look like it was chrome plated very well from the factory back there, but it looks a heck of a lot better now vs the black paint. I didn't go crazy cleaning everything, but I gave it a good scrub to get most of it off.
Attached Thumbnails The "What did you work on today" thread.-img_0269.jpg   The "What did you work on today" thread.-img_0272.jpg   The "What did you work on today" thread.-img_0274.jpg   The "What did you work on today" thread.-img_0276.jpg   The "What did you work on today" thread.-img_0277.jpg
The "What did you work on today" thread.-img_0278.jpg   The "What did you work on today" thread.-img_0279.jpg   The "What did you work on today" thread.-img_0281.jpg
Old Jun 11, 2017 | 06:54 PM
  #248
had noticed some serious fading on the hood - so today tackled it - wash, clay bar, Mequiar's Ultimate compound and finished up with MeQuiar's Carnuba Gold plus. by no means perfect but definitely much better!!
Attached Thumbnails The "What did you work on today" thread.-img_20170611_090139-002-.jpg   The "What did you work on today" thread.-img_20170611_090834-002-.jpg   The "What did you work on today" thread.-img_20170611_092258-002-.jpg
Old Jun 11, 2017 | 08:36 PM
  #249
mhminnich's Avatar
When I worked in aviation, a guy showed up one day to clean his badly faded Cessna. He went over it with mop and glow! To my surprise it turned out well. I've since used that temporary trick a time or two.
Old Jun 11, 2017 | 10:17 PM
  #250
KittyCatOne's Avatar
Spent the day trying to locate a coolant leak. It stopped leaking when the sun went down and is now holding pressure. Sigh...
Old Jun 12, 2017 | 05:47 PM
  #251
bobhoff's Avatar
Changed O2 Sensor. Cleared P1647 Code. Waiting to see if it comes back.
Old Jun 18, 2017 | 03:31 PM
  #252
Cleaned and then treated the top with 303 Aerospace using a microfiber rag as an applicator. Attached a pre-treatment pic to compare to the post treatment. It darkened the top a bit and made it look less faded. Finished putting a one step polish/wax on the old lady. Cleaned most everthing else including the interior. Applied 303 Aerospace to the interior, though I think next time I'll use Meguiars Hyper Dressing 4:1 as the 303 was too glossy for my tastes.
Also stopped by a British car meet and forgot to get pictures.
Attached Thumbnails The "What did you work on today" thread.-img_0289.jpg   The "What did you work on today" thread.-img_0303.jpg   The "What did you work on today" thread.-img_0305.jpg
Old Jun 18, 2017 | 05:30 PM
  #253
mhminnich's Avatar
Replaced the ac pressure switch, a couple more suspect o-rings, and serviced the system. It was cool, but I think it's leaking down still.
Old Jun 18, 2017 | 05:54 PM
  #254
michaelh's Avatar
Finally... finished the cooling system refurb and condenser + receiver dryer replace. Just need the gas man to recharge and we should be good. I might actually need it this week as the temps are in the high 20s.
Only casualty was the little plastic locking t*tty on the temp sensor harness fell off so I'll need to identify the part & replace it.
Went for a run and all good except ABS light came on. Wait.. it's gone away again. Module surgery time I think.
Also got the 306 exhaust apart as it's blowing at the manifold/cat joint. Had to saw through the two clamp bolts as they're 8mm heads with 10mm nuts and had gone the way most exhaust bolts do. Stupid design and they're a pig to get a hacksaw to.
Old Jun 19, 2017 | 06:33 AM
  #255
Salo's Avatar
Default small details make a difference
share some pic's of some details..
- added "Supercharged" emblem in the rear
- added a mesh grill net on the rear Arden spoiler - to match the front grill
- mounted a black rubber protection on the Arden side spoiler - as glassfiber get small cracks/holes from stones etc
Old Jun 19, 2017 | 12:02 PM
  #256
mhminnich's Avatar
Nice work! It's that last 10 percent that really makes a difference.
Old Jun 22, 2017 | 02:32 AM
  #257
Salo's Avatar
Default "Low coolant level" warning drives me crazy !
ordered a new coolant fluid level sensor (part LNA5740AB) as the red warning "Low coolant level" drives me crazy !
Old Jun 23, 2017 | 04:08 PM
  #258
Redeye's Avatar
Replaced second downstream o2 sensor and FINALLY took out faulty break light switch. First time in a couple of years I don't have that annoying 'Check rear lights.... ' warning message on thre Dash!
Old Jun 24, 2017 | 08:50 AM
  #259
ralphy's Avatar
It wasn't done today but here's the result taken over several weeks.
Wanted to generally clean up the nose (paint was rather stone-chipped and there were a couple of scuffs) plus I wanted to to lose the rabbits teeth and fit a new grille.
So off with the nose-cone:
Remove the teeth and attack the plastic underneath them:
Turning attention to the nose-cone, I prepared the surfaces for priming and whilst doing so I had an idea: to remove the badge and fit it to the grille.
Off to my guy for painting and whilst it was away I took the opportunity to have a good clean up of the front end, including the headlights, power washers and replacing the alarm module. Once the cone came back back I fitted the new grill, mounted the badge to it and the foglight and reassembled the lot back onto the car. As you can see, I had made a mistake at some point...
Error rectified, I made up a support bracket for the number plate, fitted that and here's the final result:
Thanks for reading.
R
Old Jun 24, 2017 | 12:02 PM
  #260
Jon89's Avatar
Well done, Ralphy. Looks great....
