What is the dumbest engineering design on XK8/R?
Old Jun 18, 2024 | 07:37 PM
scottatl's Avatar
Default What is the dumbest engineering design on XK8/R?
I am stupified that an engineer put a $1 gasket on an oil plug above the transmission so changing it costs $1,000+,
Anything dumber than that?
Popular Reply
Jun 19, 2024, 06:44 AM
giandanielxk8's Avatar
giandanielxk8
The front shock mounts. That they have required re-engineering by forum members speaks to their **** poor design.
Old Jun 18, 2024 | 09:00 PM
zray's Avatar
Poor quality cam chain tensioners
Z
Old Jun 18, 2024 | 09:53 PM
Y2KJag's Avatar
The moronic design of the non-access to the diff drain/fill plug.
The lunatic A/C suction hose that can't be removed with the engine in the vehicle (pre-2002 models)
The ridiculously high seating position in the X100. Was their target demographic 5' 6"?
The fuel tank inside the trunk deserves an honorable mention.
Old Jun 18, 2024 | 10:30 PM
Kuddlesworth's Avatar
The rear vent behind the rear wheels. It fills up with water even with the plastic and rubber memberane thing that is meant to let air out but keep water from getting in. I assume the fuel tank position is there to keep the weight near the center of the car which would be better for handling.
Old Jun 19, 2024 | 12:12 AM
White Out's Avatar
Oil cooler placed where a skid plate should be.
Old Jun 19, 2024 | 02:26 AM
thegreatgarbanzo's Avatar
Hey.....I resemble that remark!
Old Jun 19, 2024 | 04:15 AM
Redjags's Avatar
The rear screws of the thermostat housing. I relented and gently lifted the intake manifold, fortunately without issues. I replaced the housing with an aluminium one and used hex cap screws on the rear. Problem hopefully solved for good.
Old Jun 19, 2024 | 06:32 AM
SCMike's Avatar
Honorable mention: the hydraulics operation of the convertible top latch, with the prize going to green showers.
Old Jun 19, 2024 | 06:34 AM
Jon89's Avatar
The entire hydraulic system for the convertible top operation. A true Rube Goldberg medal award winner....
Old Jun 19, 2024 | 06:44 AM
Old Jun 19, 2024 | 07:42 AM
Dr. D's Avatar
Dead pedal for drivers over 6 1/2 feet tall.
Easy access to boot lid and fuel flap via driver's knee.
Old Jun 19, 2024 | 10:22 AM
michaelh's Avatar
Upper control arm bushings. Design OK, execution fail.
Plastic plumbing parts.
Cup holder anyone?
Old Jun 19, 2024 | 10:54 AM
XKDreams's Avatar
The infotainment system is archaic for a premium car, released in 2015!
- Why no bluetooth music streaming?
- No outside temperature display on most of the screens? It should be selectable.
Adaptive cruise control was an option on a car that has a heated steering wheel & heated windshield.
Why aren’t settings like, seat memory, mirror position, time, window setting, remembered when the battery is disconnected?
Old Jun 19, 2024 | 12:26 PM
bladerunner919's Avatar
Wrong car! We're talking X100, released in 1996.
Old Jun 19, 2024 | 12:35 PM
fmertz's Avatar
The gold medal in this category has to be the "pollen filter", fortunately rarely installed, requiring 4-hour labor to replace. On the flip side, Jaguar seemed to have communicated these facts very poorly to the filter manufacturers, making availability, at least for a time, cheap and plentiful.
Somewhat distant second to me is the higher-then-necessary position of the windshield wipers at rest, braking the otherwise clear line of sight to these gorgeous front fenders. Then again, being a British car, I could see where wipers remaining at rest is a rather rare occurrence. Or so I am told.
Old Jun 19, 2024 | 12:37 PM
XKDreams's Avatar
ohh…oops. MEA CULPA…
Old Jun 19, 2024 | 02:13 PM
Rex's Avatar
Rex
No passenger grab bar in the coupe.
Old Jun 19, 2024 | 02:47 PM
blindside's Avatar
The crappy charging/electrical system where if I don't drive my car for a week then the battery is dead
Old Jun 19, 2024 | 06:44 PM
scottatl's Avatar
Why do you say the control arm is a fail?
Old Jun 19, 2024 | 06:58 PM
JACKP's Avatar
Radiator expansion tank hidden behind wheel with no access.
Fake gauges.
Heater hose that requires removal of intake manifold for replacement
Almost impossible to reach fuel lines on fuel tank
