what engines can I use in 2001 xkr
Old Nov 6, 2014 | 02:12 PM
baddawg's Avatar
Default what engines can I use in 2001 xkr
2001 XKR, 100k, motor seized after catastrophic oil leak. looking for options.
Prefer to stay away from the Nikasal blocks.
1. Can I use an XJR - 4.0L from 2001 or 2002 ?
2. Can I use an XK8 or XJ8 4.0 from 2001 or 2002 and use my donor XKR motor for parts?
Any additional thoughts on motor swap? or links I haven't found?
Thanks,
Old Nov 6, 2014 | 02:32 PM
brgjag's Avatar
got spare cash and can do this yourself I would go this route, put some American muscle in that baby...
Jaguar Specialties
Old Nov 6, 2014 | 02:33 PM
brgjag's Avatar
I would think the computer for your car is diff than the normal non XKR cars. So unless your put another XKR set up in it you may run into computer issues????
Old Nov 6, 2014 | 03:01 PM
RJ237's Avatar
You can use the blocks, put your old heads, etc. on it
Old Nov 6, 2014 | 04:44 PM
avos's Avatar
You can use any 4.0 XKR block, and if you want to avoid nikasil, just ensure the engine is build after October 2000.
Do not use 4.0 XK8/XJ8 engines!
Another option worth to consider is the later 4.2 engine.
Old Nov 6, 2014 | 06:40 PM
brgjag's Avatar
Will the 4.2 work. It is my understanding that the computer set up is diff to the 4.0
Old Nov 6, 2014 | 06:45 PM
RJ237's Avatar
To keep things simple it's best to stick with a 01-02 XKR or XJR block. The Xk8 pistons are higher compression and will not work.
Old Nov 6, 2014 | 07:02 PM
RJ237's Avatar
Just had an additional thought. I believe the timing chains were changed in 02, so that would require transferring the chains and sprocket from the 01.
But I'm out of my depth here and someone with more knowledge should be consulted.
Old Nov 7, 2014 | 12:51 AM
baddawg's Avatar
Thanks for the feedback, have located several XKR motors 2001 / 2002 from wrecked cars, in the $2,500 range, should make the swap a lot easier and i can take care of water pump, tensioners, etc. out of the car.
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
Sprayall
Sep 3, 2015 07:49 PM
obwoodie
Sep 3, 2015 07:45 PM
TC Johnson
Sep 2, 2015 09:30 AM
