What is the ground clearance on a standard XK8/XKR
Old Apr 27, 2018 | 06:22 AM
  #41
Supersprint's Avatar
Default UPDATE
New Adamesh front springs installed now.
Front ground clearance raised by 50mm ( 2 inches ) from 90mm to 140mm. Both front and rear end is now lowered by 25mm' ish.
I was a little worried about what this would do to the look of my car, but honestly: it's still a good looker isn't it
The comfort of the drive is VERY much improved. These stupid low Majestic springs where really bad for the car.
I love the car even more now and hereby say THANK YOU to all who contributed in this thread
A few pics from the proces and the mandatory "before and after" photos.
Carsten
Before
After
Old Apr 27, 2018 | 07:15 AM
  #42
Looks good.
Did you have any trouble compressing the springs? Some people seem to struggle.
Old Apr 27, 2018 | 07:20 AM
  #43
fmertz's Avatar
Did you get a chance to measure the thickness of those coils? Looks like the old springs may have thinner coils, making the spring _rate_ lower ("softer" spring). Technically, the old spring looks taller at rest. No wonder you were bottoming out...
Old Apr 27, 2018 | 08:28 AM
  #44
toaster's Avatar
Looks better than ever!!!!
Old Apr 27, 2018 | 08:32 AM
  #45
toaster's Avatar
Seems the Adamesh has 1 coil/turn more.......
Old Apr 27, 2018 | 09:03 AM
  #46
Originally Posted by Norri
Looks good.
Compressing the springs was easy using my power drill/driver and a set of these:
Old Apr 27, 2018 | 10:09 AM
  #47
rothwell's Avatar
I think that looks perfect. Nice work. Glad it worked out so well.
Old Apr 29, 2018 | 10:40 PM
  #48
bcprice36's Avatar
Smile Supersprint is way low!
Supersprint,
Your front fender was setting about 1/2" below the top of your Tire, when it should be about 1/2" above your Tire...It appears you have changed the Springs now as it looks about the same as mine now! They should always set where the Fender is about 1/2" above the Tire... My XKR has the Handling Package and 20" Montreal's.....And I'm assuming your Wheels are 18" Centuar's but either way for drivability, you need about 1/2"...
Billy Clyde in Houston
What is the ground clearance on a standard XK8/XKR-sunday-%40-bush-park.jpg
"Click to Enlarge"
whosedream
Aug 15, 2017 03:57 PM
kashaf
May 21, 2014 10:52 AM
trev
Nov 4, 2013 10:52 AM
Lug_Nut
Aug 17, 2012 04:30 PM
Tiko89
Mar 8, 2011 10:06 AM
