what is this thing? 04 XK8
Old Jan 25, 2012 | 07:39 PM
hradical's Avatar
Default what is this thing? 04 XK8
Hi everyone,
I want to thank those who helped me find the ghost in my door. New switches have been ordered thanks to Dr.DSB. I now know what I will be doing Saturday.
I have another issue. I have a coolant leak at that front of my motor. The plastic water manifold has issues. I have attached pics. Can someone tell me if this is the thermostat housing. I found the metal version on Ebay, but the pics don't look the same.
Any input is appreciated.
Attached Thumbnails what is this thing? 04 XK8-imgp1133.jpg   what is this thing? 04 XK8-imgp1132.jpg
Old Jan 25, 2012 | 07:51 PM
test point's Avatar
That is your thermostat housing but not the one that the '97 - '02 engines used that is available as an aluminum version. The '03 up housing has not surfaced as an issue . . . yet. Congratulations, you may be the first.
Old Jan 25, 2012 | 08:42 PM
Stratohammer's Avatar
Rest assured, that won't be the first. I had to replace mine a few years ago due to leakage - at a mold line, if memory serves. The new part was on the order of $75 and came with a new thermostat and temp sensor.
Mike
Old Jan 26, 2012 | 02:53 AM
Originally Posted by hradical
........Can someone tell me if this is the thermostat housing. I found the metal version on Ebay, but the pics don't look the same.
It is a Thermostat Housing - YES
Like test point, I'm puzzled by the shape of it. The ones you've been looking at on eBay probably look like Items 1 to 3 in this:
What Model Year is your XK8?
Old Jan 26, 2012 | 11:14 AM
hradical's Avatar
I have an 2004 convertible.
Old Jan 26, 2012 | 11:15 AM
hradical's Avatar
Stratohammer, was your replacement metal? where did you find it?
Old Jan 26, 2012 | 01:08 PM
It's all in the detail!
You have a 4.2 litre normally aspirated engine? The JPG I attached to my earler post was for the 4.0 litre normally aspirated engine. This is the one that regularly fails and is available as a metal alternative.
The original plastic one is on the left and the aftermarket aluminium replacement on the right.
Yours is completely different:
what is this thing? 04 XK8-xk8-thermostat-housing-4.2-ltr-normally-aspirated.jpg
I haven't seen these as yet available in metal. Is that a split where the orange coolant staining can be seen in your photos?
Old Jan 26, 2012 | 01:51 PM
hradical's Avatar
Its leaking at the base of the small vertical "pipe" where the overflow line is connected.
Old Jan 26, 2012 | 05:37 PM
The part that's damaged is called the 'Water Rail & Thermostat Outlet Pipe'. and there's four different versions listed for the normally aspirated engine depending on VIN number.
The plastic cooling system components aren't cheap. Best option is to bite the bullet and buy a replacement but you may want to consider attempting to repair it.
The vertical 'pipe' is the vent to the expansion tank. If it's only cracked where it connects to the larger horizontal pipe and not completely broken off, it's likely to be repairable without having to remove it from the car using a bead of epoxy waterproof putty.
If you choose this approach, the outlet pipe will have to be prepared by thorough cleaning and drying which will involve draining off a small volume of coolant.
Old Jan 27, 2012 | 11:23 PM
H20boy's Avatar
I've replaced my tstat housing, dealer only replacement part. Not expensive either.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
Wolfy
Sep 10, 2015 09:50 AM
