What's in the bag?
Old Sep 26, 2013 | 07:01 PM
BurgXK8's Avatar
Default What's in the bag?
I found this in the spare tire area of my 2003 XKR. It's got some tire valve looking things inside of it, but not sure for what purpose these parts are to be used.
Thoughts?
Old Sep 26, 2013 | 08:01 PM
test point's Avatar
Got the wheels without the valve stems?
Old Sep 26, 2013 | 08:19 PM
Bad Cattitude's Avatar
That is the adapter kit for filling the BBS wheels with air. I believe they had a 'hidden' valve stem.
Old Sep 26, 2013 | 08:32 PM
SeismicGuy's Avatar
That bag and the stuff in it is like gold--just try pricing this little kit from a Jaguar dealer.
If you have the BBS wheels you will need the valve adapter. You can use a penny instead of the "T" tool to remove the threaded cover over the valve hole so the only must-have part of the kit is the valve adapter. In fact you should try and find extras of these from BBS or wherever, just in case.
Doug
Old Sep 26, 2013 | 09:20 PM
rothwell's Avatar
Yeah that is the same kit that came with the BBS wheels on my VDP. I still have mine thankfully.
Old Sep 27, 2013 | 06:09 AM
BurgXK8's Avatar
Thanks; figured it had something to do with the valves. Funny thing is I just had the two front tires replaced but there was no mention by the mechanic of needing that kit to inflate the tires, so I'm not sure that he used it or had something similar on hand.
Old Sep 27, 2013 | 06:11 AM
BurgXK8's Avatar
Doug
Ok, I'll bite - what's a replacement kit cost from the dealer? Maybe BBS sells it directly. Hoping I don't need to find out.
xjrjag
Aug 17, 2019 03:45 AM
Swagguar
Aug 11, 2019 04:50 PM
Collector1
Sep 28, 2015 03:52 AM
Larry-Cleveland
Sep 25, 2015 08:42 AM
DustysSon
Sep 13, 2015 04:17 AM
