Wheel Fitting & Removal Alignment Tool
Old Nov 25, 2021 | 09:45 AM
DougXK8's Avatar
Default Wheel Fitting & Removal Alignment Tool
Does anyone know where I can purchase a tool like this for my XK8. I have 20" Detroit wheels that are very heavy to fit and having something like this will make it easier to put the wheels back onto the car. I am told that the wheel nuts on the hub are M12 size. The company in the UK that provides these for Range Rovers/Land Rovers only make M14 tools.
Old Nov 25, 2021 | 01:10 PM
xalty's Avatar
they are 1/2-20 UNF
Old Nov 26, 2021 | 05:51 AM
drmike's Avatar
If like me you struggle to get the wheel up to the right height to engage the lugs I use a broad tyre lever under the bottom the wheel. I find it offers just enough leverage to lift it to the right height and enough wobble to get the alignment. But I may well have misunderstood the problem!
Old Nov 26, 2021 | 12:05 PM
max224's Avatar
I believe the thread size is 12mm X 1.5. Here's a link to some hanger pins that might work for you. They're out of stock with this company, but if you copy and Google the part number there are ebay vendors that also carry them. There also kits available that carry assorted sizes of these tools.
Good luck!
https://www.cpooutlets.com/9-circle-...96005-221.html
Old Nov 26, 2021 | 12:41 PM
Dr. D's Avatar
  • Doug, I have had results using copper plumbing pipe similar to the threaded tool that you posted.
  • Mike, I have had results using Rebar similar to the wheel lift bar that you posted.
Regardless, I opt to just get on my knees and roll the wheel on to my lap so to speak. I adjust its height by rolling the wheel either toward my knees or toward my waist. This is just my technique as I am 73 and probably only average strength . This is how I handle my 20" Dodge Ram wheels which I would guess are just as heavy.
Old Nov 26, 2021 | 01:10 PM
xalty's Avatar
Good luck!
the X100 is not metric, it’s 1/2-20
Old Nov 26, 2021 | 02:47 PM
Johnken's Avatar
DMike, I thought it was just me :-)
Every time I go to put then on I think to self - "how can this be so %$#@%'ing hard :-)
John
Old Nov 26, 2021 | 03:13 PM
Terrific's Avatar
We always used a shovel to lift and align the wheel on trucks and equiptment. Works equally well on heavy car tires. Simply put tire up against hub, put shovel under outer edge of tire and lever down to lift and align.
Old Nov 26, 2021 | 04:04 PM
Dr. D's Avatar
Sounds good if working room is available.
Old Nov 26, 2021 | 04:49 PM
DougXK8's Avatar
Hi Max224, they appear to be just what I am looking for, BUT it appears they only sell to the USA and I’m in the U.K.! Just my luck that I can’t find these tools in the U.K.!
Old Nov 26, 2021 | 05:02 PM
DougXK8's Avatar
For the rest of the comments, thanks for your suggestions. I am now considering a wheel removal/lifter trolley. Although these are around £500-£600 in the U.K., it may help me from getting a hernia!!
Old Nov 26, 2021 | 05:39 PM
xalty's Avatar
https://www.ebay.co.uk/itm/ZORO-SELECT-LINKT164-1-2-20-x-6-Plain-Aluminum-Double-End-Internal-Threaded-/284212426667?mkcid=16&mkevt=1&_trksid=p2349624.m46 890.l6249&mkrid=711-127632-2357-0
or use two of these with a threaded rod
https://www.ebay.co.uk/itm/233561590973?hash=item36615b0cbd:g:OKUAAOSwvvJfLn2 g
Old Nov 27, 2021 | 01:55 AM
DougXK8's Avatar
xalty Again, this looks like what i want BUT in the postage description is says "May not post to United Kingdom."
Old Nov 27, 2021 | 01:57 AM
drmike's Avatar
If you want a wheel trolley/lifter then ask around and see if anyone will make you one. I was a rubbish welder but I made a simple wheel dolly that doubled as a lifter. Cost in parts was under £20. Time for me was more than a pro would take. Could you bodge a sack trolley with a slightly longer platform?
Would this do?
Old Nov 28, 2021 | 06:26 PM
CorStevens's Avatar
i use an old skateboard and adjust the height of the car with the trolley jack. Easy.
Old Nov 29, 2021 | 01:27 AM
drmike's Avatar
Nice one. No skateboards here though.
Old Nov 29, 2021 | 12:48 PM
Gas turbine's Avatar
I believe the Jaguar Project 8 with carbon brakes has two wheel fitting pins in the tool kit to avoid damage to the brake discs. I have been unable to establish the part number or thread size of these tools but it’s possible they could be purchased from Jaguar if they fit. Can anybody provide further information on these Jaguar supplied wheel fitting pins?
Doug Dooren
22
Aug 9, 2022 06:27 PM
max224
Nov 14, 2021 03:27 PM
SteveX150
Jul 13, 2021 06:38 PM
sg18438
Mar 26, 2016 05:28 PM
Stuart S
Mar 26, 2014 07:58 AM
