Wheel paint
Old Jul 23, 2021 | 12:42 PM
Canuck pump engineer's Avatar
Default Wheel paint
I need to touch-up the 19" Apollo wheels on my 2003 XK8. Does anyone know what kind of paint is a close match to the original metallic silver and where I might obtain it? A paint or colour code?
Thanks!
Old Jul 23, 2021 | 03:19 PM
JayJagJay's Avatar
Thanks!
You'll RARELY hear me say this,,,,,
THAT is a job for the professionals.
And there are lots of them out there.
Old Jul 23, 2021 | 10:00 PM
rothwell's Avatar
Well...maybe.
My Apollo Wheel Restoration
I was able to get a touch up pen from Jaguar for my 2011 Aleution wheels. I never looked for paint to match my Apollos but it probably existed at some time.
BTW I still have the original full set of Apollos I removed from my 2004. Probably should sell them now that the XK8 is long gone.
Old Jul 24, 2021 | 04:17 AM
XK Owen's Avatar
Thanks!
Did you paint those calipers yourself?
My Brembos are silver with jaguar written on them. I like the green though, would look nice on my jaguar racing green car!
Old Jul 24, 2021 | 06:59 AM
JayJagJay's Avatar
Cool!
Ok... Shifting from being a hater - to listening and learning...
Any cooking to cure the paint?
Any special steps?
Did it, or do you think it would/will hold up?
Old Jul 24, 2021 | 07:30 AM
STLTHMSTA's Avatar
I'm with you Jay, but I think Rothwell IS a professional. Wow those look great !! When I curbed my right sides I took them to a local Pro and they did a great job.
The OP Cunuck is from Car crazy Atlanta, I'm sure there are repair places there to help him out. If he does want to do the job himself. But he could. TM
Old Jul 24, 2021 | 11:58 PM
rothwell's Avatar
Since Brembos won't fit under Apollos I am going to take a guess that's a cover. Agree about the color.
Old Jul 25, 2021 | 11:13 AM
Hi Owen
What you see are actually just cheap ABS covers I attached to my standard calipers. I painted them green (to match the wheel centre caps and nose badge), applied Jaguar logo decals, and clear coated them. I opted for covers rather than painting the calipers due to my concerns about surface prep and caliper high temps. I left a small air gap between the calipers and covers to dissipate heat. Seems to have done the trick as the covers still look OK, in my opinion anyway, after almost five years on the car.
BTW, Owen, the XKR overriders you sent me worked out great. Much appreciated. Thanks again!
Bill
Old Jul 25, 2021 | 11:15 AM
Rothwell: Yep! You caught me. Just caliper covers.
Old Jul 25, 2021 | 12:07 PM
XK Owen's Avatar
Covers or not, I think they look great. Going have to put painting mine green on my todo list now!
Glad the overriders worked out. A much better home for them than the back of my garage!
Old Jul 25, 2021 | 12:14 PM
Norfolkrob's Avatar
I have a similar conundrum. My bbs Montreal’s off my 05 xkr are getting a professional refurb next month (new valves, outer bands and inner alloy paint) however in the past someone has badly restored them and painted the middles a different shade. Now I have no reference to ask the garage to paint them to. So any one who does have any idea where to find a colour reference then I’m all ears
Old Jul 27, 2021 | 09:08 AM
Norfolkrob,
Somebody just told me the name of the paint colour is "Jaguar Sparkle Silver". I'm researching that.
Also, here's a link to a posting that might provide some clues: https://www.jaguarforum.com/threads/...-colour.95810/ I hope this is helpful.
Old Jul 27, 2021 | 10:50 AM
TropicCat's Avatar
If you can't locate a paint code or matching paint you can always "touch up" all 4 with the same silver color & clearcoat. It's a lot more work but only you'll know the difference.
Old Jul 27, 2021 | 05:18 PM
TropicCat,
Yes, in the end it may come to that. I hope not, but I will do whatever I must to do it right.
Old Jul 27, 2021 | 07:11 PM
giandanielxk8's Avatar
I have known about this for quite a while, but I don't know the reason why? I really like the Apollo's and would gladly take them off of your hands, but I do have Brembo's, and I like those more, especially now that I have Redstuff pads.
Old Jul 30, 2021 | 12:15 PM
TropicCat's Avatar
TropicCat,
Dear Canuck. The engineer in me would also do whatever is necessary to do it right too.
Old Aug 1, 2021 | 12:27 PM
Shoreguy's Avatar
Veteran: Air Force
Well here's what I did with my Apollos and the results were very good. Had rash on three of my wheels (one got away) and decided to try getting the rash out myself before getting them redone by a shop.
OK so I read somewhere on this site about DupliColor Ultra Silver Metallic BGM0508 being a very close match to the Apollos (probably others).
Lightly filed then sanded starting with 150 grit finishing with 500 grit using a orbital sander and by hand. After I was done other then the color difference they looked very good.
Didn't want to spray wheels just wanted to make my repair blend. I sprayed the DupliColor into a small cap and added a small amount of lacquer thinner. To apply it used a medium sized blending artists brush which holds a good amount of paint. The goal is lay on a even layer of paint in one pass to the outermost flat side of the rim. Let them dry and you would have a hard time seeing the repair if you didn't know about it.
I used no primer or any other coating just the paint and lacquer thinner.
That was two years ago and they still look great. No peeling, color change, etc... It worked for me and saved me some money for once.
Old Aug 1, 2021 | 04:48 PM
Shoreguy - Thanks! I'll give that DupliColor BMG0508 a try.
I had planned to apply whatever paint I did find with an airbrush.
Old Aug 1, 2021 | 06:34 PM
Shoreguy's Avatar
Veteran: Air Force
Well I usually spray everything but in this case I just wanted to zero in on the damaged areas not paint the entire wheel. This worked out really well for me. Good luck
user 2029223
Apr 16, 2025 01:09 PM
Jul 25, 2021 02:11 PM
jagtoes
Jul 14, 2018 08:39 PM
95Leaper
XJ40 ( XJ81 )
Jun 13, 2017 11:48 PM
Jag13cat
Oct 10, 2010 06:01 PM
