White "smoke" out the back and disappearing coolant! - 2000 XKR vert
Old Apr 4, 2014 | 10:21 PM
Abby's Guy's Avatar
Default White "smoke" out the back and disappearing coolant! - 2000 XKR vert
Oh, boy! Been running a bit rough at start up, but smoothed out fine as it warmed. Coolant began disappearing. Hmmm. My brother (former mechanic) said he sold his truck when coolant began disappearing. Started it today and after about 30 seconds got lots of white stuff out the exhaust, more from the right than the left, but significant from both sides.
A new contact in Salem, Oregon (Troy, of Affinity-Imports) agrees it's probably a head gasket. He also said it might be cheaper to buy a new used engine than fix this one. Hmmm. $5-7k. I saw someone mention on a thread here that there might be a possible intercooler leak if the smoke was on both sides. But wouldn't the exhause mix in the middle of the x-exhaust? Hoping for a cheaper outcome. Any thoughts or hope? Pricing thoughts? I'm getting tired of taking my cat out on a trailer.
Old Apr 5, 2014 | 02:01 AM
plums's Avatar
Get your brother to explain coolant tester kits to you. It can detect combustion gases in the cooling system. That would be your first step to confirming a blown head gasket.
You can always go for a good used engine rather than a new engine.
Old Apr 5, 2014 | 03:36 AM
I'd definitely start with buying a tester kit before buying an engine!
If it confirms the worst then there's an old saying "better the devil you know than the one you don't". Gasket replacement on the original engine (provided neither head nor block is cracked) for which you presumably know the history is preferable to a used replacement engine of unknown provenance.
Old Apr 5, 2014 | 05:55 AM
GMad's Avatar
Originally Posted by GGG
+1
Yes I would agree with that, although a tester kit wont tell you which head gasket is blown!
Although having said that, if there is more smoke (steam) coming out of the right hand side, then that is certainly a good starting point. Plus the worse case scenario is that you might end up doing both heads! In fact if it were me, I think I would do both anyway..
Old Apr 5, 2014 | 05:57 AM
XJR-99's Avatar
+1
+ you can install better gaskets at the same time.
Old Apr 6, 2014 | 12:57 AM
Abby's Guy's Avatar
Default Thank you
Yes, I'll be looking for test kit tomorrow. On another thread I saw that the 4.2 gaskets are a better choice than the 4.0 gaskets. Will be choosing those. I'm NOT a mechanic, and don't have a lot of choices in southern Oregon. But even on the Jag $5-7K seems like a lot. Is that reasonable?
Have to share something another brother told me. When considering whether or not to spend the money to fix a car, consider: If this car were for sale for the amount this fix will cost, with the work just done, would I be interested? In this case, of course!
Thanks for the help.
Old Apr 6, 2014 | 06:52 PM
magnum454's Avatar
It's not a good way but try some radiator sealant. It worked for me on a t-bird for years.
Old Apr 6, 2014 | 06:56 PM
magnum454's Avatar
By the the sealant was "silver seal" get it at any parts store.
Old Apr 6, 2014 | 08:39 PM
WhiteXKR's Avatar
Do not use radiator sealant in these cars. There are a number of valves in the cooling system of the XK8/R and the sealant will likely cause them to malfunction, multiplying your headaches.
Old Apr 7, 2014 | 10:14 AM
magnum454's Avatar
Sorry, didn't know that.
Old Apr 7, 2014 | 03:21 PM
Abby's Guy's Avatar
Default Price in $
So, what price range should this be in at an indie shop?
Old Apr 7, 2014 | 04:16 PM
oldmots's Avatar
The test is a compression test. This will tell you which side is blown. You don't need to replace both gaskets if only one is blown. These engines are not known for blowing headgaskets, so there is no need to replace one that is still holding compression. The cost to only replace one headgasket is going to run around $1500. You don't need a specialist, any good mechanic can do this. The only danger is pulling it down and finding a damaged head or block. This could trigger a replacement engine.
Old Apr 22, 2014 | 02:59 PM
Abby's Guy's Avatar
Test indicates hydrocarbons in coolant.
Car is now at a local shop with good reputation/referrals. Not a Jag shop, but known for quality work and honesty. Their plan is to replace all wear parts as far into the engine as they get. Seems reasonable. Estimate looks in order, clear.
Wondering - do I need to have the updated timing chain set (chain, guides, gears, and tensioners) as dealer records show tensioners updated before I bought the car two years ago?
Is there a need to charge the A/C system? It was working fine.
Also having head pressure tested and resurfaced.
Requested they use the 4.2 gasket, as noted on another thread. He said he'd have to check on that because he orders the gasket kit.
Also rodding out radiator.
New plugs, new water pump.
ANYTHING ELSE I SHOULD LOOK FOR?
Old Apr 22, 2014 | 11:29 PM
Autobahn kid's Avatar
Replace heater hoses in the valley. Perhaps also knock sensors.
Old Apr 23, 2014 | 01:28 AM
Abby's Guy's Avatar
Thank you.
MJ'S Jag
Nov 10, 2022 08:14 AM
nelsonht
Aug 30, 2015 06:01 AM
TC Johnson
Aug 29, 2015 08:55 PM
peterg19
Aug 28, 2015 08:42 AM
dpappyp
Aug 27, 2015 06:31 AM
