Windscreen Washer?
Old Jan 25, 2016 | 02:47 PM
JagTheRipper's Avatar
Default Windscreen Washer?
Hi,
What's the easiest point for measuring if electricity is being delivered to the washer pump? My wipers start moving when I press the button but washer won't come on... 2003 XKR
Old Jan 25, 2016 | 02:53 PM
Jon89's Avatar
The washer fluid hoses or squirt nozzles may simply be clogged with debris. Not unusual for that to happen on any older car regardless of make. I would clean them first before checking the current to the pump....
Old Jan 25, 2016 | 03:07 PM
Thanks. I will check that too but I can't hear the pump either even with the engine off...
Old Jan 25, 2016 | 03:51 PM
brgjag's Avatar
my 03 I thought mine were dead, could not hear pump. turns out in the cowl there is a T that was busted so it was just squirting into the cowl. The lines go through the drivers front cover panel, in with the brake booster area. take a line in there and if I recall you can take it off and see if it is working. I pulled the wipers and cowl cover off mine and just rigged it to work. The orig set up they have check ***** in the system under the cowl. I just took that crap out and ran it old school with some T's and hose.
Old Jan 28, 2016 | 10:40 PM
wolfpck1's Avatar
The Windscreen Washer Pump (item 5) is Fuse #7 (15 amp) in the Driver's side fuse box. The separate Powerwash pump (item 8) is Fuse #7 in the engine compartment fusebox (LH).
Old Jan 29, 2016 | 12:21 PM
SeismicGuy's Avatar
See my post #15 in this thread:
https://www.jaguarforums.com/forum/x...working-63525/
In my case, not only was the little check valve broken but someone (likely the mechanic) punctured/crushed the little rubber tubes when they removed and replaced the plastic cowl/plenum.
Doug
Old Jan 30, 2016 | 09:38 AM
Turns out to be the pump itself. Voltage was delivered to the pump but it wouldn't run. Took it out and verified the diagnosis using a lab power supply. Ohm meter shows it's almost shorted (~2 ohms).
Old Feb 5, 2016 | 03:21 PM
Thought I'd update this thread as I just received the new pump. The new pump also showed about 2.5 ohms on the motor coil so maybe that wasn't a good fault indicator after all. Anyway the new pump has no trouble running on the same lab PSU so problem sorted
HawaiiRealtor
Feb 4, 2016 03:39 AM
kmmoore1013
Feb 2, 2016 06:46 PM
Panthera93
Jan 25, 2016 09:20 PM
HawaiiRealtor
Jan 25, 2016 12:40 AM
Bsimps
Jan 19, 2016 10:55 PM
