Wiring RCA audio input to premium stereo - help
Old Aug 2, 2016 | 09:58 PM
Jandreu's Avatar
Green wire is the right channel, blue wire is the left channel, shields are common to both channels
Old Aug 3, 2016 | 08:43 AM
Grif's Avatar
Think i may have spliced into the wrong side of the AI-net connector! Kills the power to HU amongst other oddities, I spliced into the cable going to the HU..
Old Aug 3, 2016 | 03:12 PM
Jandreu's Avatar
The wires are very fine, I actually opened the Amp and spliced in at the board where the AI-Net cablecomes from the CD.
Old Aug 3, 2016 | 03:44 PM
Grif's Avatar
Here's what I did that didn't work. When I connected the wires from the Parrot harness it completely disabled the HU, no power at all. Any help appreciated!!
Old Aug 4, 2016 | 12:12 AM
Jandreu's Avatar
see page 13 on the attached file, the white wire you cut is the Bus Ground and the red wire you cut is the Bus data.....wounder why nothing works..LOL
You need the Green and Blue wire for the audio channels.
The attached is a very informative write up by another forum member.
File Type: pdf
Old Feb 20, 2021 | 10:41 PM
Jason Iupe's Avatar
Default How do I know what wires in the rear on the subwoofer and I have 2019 jaguar XF to wi
In the rear of my 2019 jaguar XF there is a factory subwoofer what wires do I need two wire in my line Apple converter
mikerocosm
Jun 9, 2014 06:57 AM
clawsrout
Nov 22, 2013 04:23 AM
achysklic
Mar 18, 2011 08:29 PM
xj8vdp
Audio/Visual Electronics
Sep 6, 2010 02:36 AM
silverj
Mar 28, 2010 12:10 AM
