Worn inside edge on all 4 tires
Old Sep 16, 2018 | 07:53 PM
charlie warren's Avatar
From: Campo, California about 65 miles east of downtown San Diego
Default Worn inside edge on all 4 tires
The inside edge of all 4 tires on my 1999 xk8 is worn down to the cords. Outside edges look new?? Where to I look for the problem? The wear is very uniform. Can I put 245x45x17 tires on as replacements instead of 245x50x17
Old Sep 17, 2018 | 06:33 AM
I would check your suspension for failed front upper shock mounts (you will find foam bits around the top of the shock), bushings, shocks all around for leaks/bad lower shock bushings, etc. Replace these, then add new tires and an alignment.
Old Sep 17, 2018 | 02:47 PM
toaster's Avatar
255/45R17 is ok.
edobernig
Sep 30, 2012 09:48 PM
andyps
May 25, 2012 01:10 PM
iownme
May 5, 2012 07:07 AM
skippy99
Jan 6, 2012 06:08 PM
Tomlite
Mar 29, 2008 06:55 PM
