Wrong tranny fluid
Old Dec 16, 2017 | 03:28 PM
larueb's Avatar
Default Wrong tranny fluid
I am looking at a '99 that was sitting for several years. Guy who bought it knows nothing about Jags so he changed the tranny filter and put in synthetic fluid. He drove it a mile, hard shift between 1st and 2nd then fail safe mode.
can the tranny be successfully flushed and correct fluid installed with no damage?
thanks.
Old Dec 16, 2017 | 03:36 PM
chillyphilly's Avatar
You can always replace the transmission fluid with the correct stuff, but the question is what kind of damage did the transmission suffer from the original mistake? Have you pulled any codes?
Old Dec 16, 2017 | 03:52 PM
Gus's Avatar
Gus
Could be the reason it was sitting for so long.
Gus
www.jagrepair.com
Old Dec 16, 2017 | 04:14 PM
brgjag's Avatar
Sat a long time, owner messed with the trans, he knows nothing about jags.
I'd look at a diff jag.
Old Dec 16, 2017 | 04:24 PM
mhminnich's Avatar
My guess would be the transmission had failed and the owner did a fluid flush hoping it would somehow resurrect it.
Old Dec 16, 2017 | 07:38 PM
RJ237's Avatar
+1. I don't think changing to synthetic is the problem. The properties wouldn't be that different. I wonder if all the transmission fluids aren't mostly synthetic now.
Old Dec 17, 2017 | 03:03 PM
phanc60844's Avatar
Probably just didnt put enough in, tranny oil is tranny oil no matter what ZF say
Old Dec 20, 2017 | 12:44 AM
phanc60844's Avatar
also, because of it standing for so long, pressure regulator stuck?
JohnnyLA
Feb 1, 2013 07:15 AM
benebob
Jul 23, 2010 03:40 PM
JanuarXKR
General Tech Help
Oct 14, 2009 09:44 PM
chaz
Jul 28, 2009 10:18 PM
lugmanhere
Sep 6, 2007 10:32 AM
