xk8
Old Jan 22, 2017 | 09:30 AM
luscombe's Avatar
Default xk8
cooling fan will not run, where are the fan relays located is there a pressure radiator cap. 1998 xk8
Old Jan 22, 2017 | 10:24 AM
DevonDavid's Avatar
Bit more information please .............
Is the car overheating ?
How do you know the fan will not run ?
If you put the AC on - do the fan(s) run then ?
Have you checked fuses ?
No - there isn't a pressure radiator cap on the radiator, but there IS a cap on the coolant reservoir (rear of engine on left-hand side looking forward. What is the level in there - should be up to the neck of the reservoir. Rather than excess pressure or coolant venting to "atmosphere" - there's a separate coolant recovery tank below the right hand side wheelarch.
Old Jan 22, 2017 | 11:05 AM
Johnken's Avatar
David's right on the money. Fans always run with ac on. Hope it's above 40degrees F out there. Every car ac I've heard of is intentionally disabled below 40 something degrees.
Old Jan 22, 2017 | 11:15 AM
test point's Avatar
The fan relays are below the radiator to the left of center but the above posts are correct. There are lots of reasons for the fans not to run before you start taking the relays apart.
BALTVISTA
Nov 2, 2017 10:38 PM
xantic
Oct 27, 2013 09:39 AM
ohjag
17
Jul 25, 2012 03:40 PM
n17gary
Aug 14, 2011 09:03 AM
BALTVISTA
Oct 1, 2009 05:33 PM
