xk8
Bit more information please .............
Is the car overheating ?
How do you know the fan will not run ?
If you put the AC on - do the fan(s) run then ?
Have you checked fuses ?
No - there isn't a pressure radiator cap on the radiator, but there IS a cap on the coolant reservoir (rear of engine on left-hand side looking forward. What is the level in there - should be up to the neck of the reservoir. Rather than excess pressure or coolant venting to "atmosphere" - there's a separate coolant recovery tank below the right hand side wheelarch.
ohjag
17
Jul 25, 2012 03:40 PM
