xk8 2002
Old Aug 24, 2008 | 06:37 AM
test point's Avatar
Default RE: xk8 2002
There have been numberous discussions about installing a switch, either in the center console or in the blank hole in the lower dash. Like most, I had never noticed that there is a blank on the other side of the steering wheel to match the temperature sensing device.The switch splices into the wires connecting to the motor in the trunk.
Old Aug 24, 2008 | 06:47 AM
H20boy's Avatar
This article was written by a fellow xk8 owner. Just have to find the switch on the internet (not too difficult) and you can have it rigged up in no time. It fits perfectly.
Old Aug 24, 2008 | 10:34 AM
test point's Avatar
Matt,
Your link doesn't work. I know I read the thread but couldn't quickly find it this morning.
The new car shifts beautifully!
tp
Old Aug 24, 2008 | 02:57 PM
H20boy's Avatar
Well, if you want the article in pdf, drop me an email or a PM with your regular email address, and i'll send it over. sorry about the link...odd. Did you try to right click and 'save as'?
Old Feb 12, 2009 | 09:47 PM
Montauke's Avatar
Hi Matt, I'm looking for the same article, sent you a PM. Hope you can help, thanks!
Old Feb 12, 2009 | 11:06 PM
SeismicGuy's Avatar
Default Antenna switch article
I think you will find the article by following this link:
http://www.maxperformancecars.com/in...=61&&Itemid=58
Doug
Old Feb 13, 2009 | 05:28 AM
Fjk's Avatar
Fjk
I had the issue with antenna noise. I put a switch on the console just behind the ashtray.
The wire controlling the antenna passes through the console. (IC2-14) it is Green with Black tracer. Farthest connector back, on the drivers side. There was enough slack in the cable, that I could cut the wire and splice in the switch without disconnecting the cable.
Old Feb 13, 2009 | 03:56 PM
H20boy's Avatar
doug, awhile back I tried this , and you have to be a registered member to get the pdf download. I just saved a copy on my hard drive. Montauke, PMs aren't working right now, send me an email matt (dot) hopper [at] att (dot) net and i'll get it to you.
i've got an extra switch too if you can't find one on the internet. blue LED i believe.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
CXJ
Aug 29, 2017 08:41 AM
JCam
Oct 23, 2016 08:27 PM
carl purchase
Oct 14, 2015 06:14 PM
jessejamestw23
Sep 26, 2015 03:57 PM
