XK8 2005 won't stay running
Old Apr 11, 2018 | 05:29 PM
Garypearson2000's Avatar
Default XK8 2005 won't stay running
I have scan code P0607 and engine will start right up and then die after one second. Suggest PCM. Is the PCM and ECM the same and what is the part number. I reset by disconnecting the battery and reset the scanner and it now reads "no codes" but will still not run for more than a second
Old Apr 11, 2018 | 10:13 PM
JBzXJ40's Avatar
ECM and PCM are pretty much the same thing - Jaguar likes to change terminology every other day for the same part.
Attached is the code description - have you had a look at the Throttle Body before condemning the ECM? Any other symptoms or warnings displayed on message center?
Old Apr 11, 2018 | 10:51 PM
skymark's Avatar
Research reveals that's an ECM fault. It may be it has failed or needs to be re-flashed by the dealer.
Are there any other symptoms like dash lights? Have you checked fuses and the ECM relay?
Did this just happen out of the blue? Any recent work done, battery problems?
Old Apr 12, 2018 | 08:14 AM
fmertz's Avatar
Not a lot to go on with that code.
There is this: successful-re-program-flash-2005-xk8-ecu-190075/
Otherwise, try and check the gas pedal. Check the cable attachment to the sensor in the bin next to the brake booster. Take out excessive slack, or put a bit of slack if too tight. It is a simple "fork" setup that can be done quickly. Then Ignition ON, engine OFF, slowly press the gas pedal to the floor and back a few times to re-tech the ECU about the range.
Remove the big intake air pipe to expose the throttle plate. Again, ignition ON, engine OFF, see if the plate moves when you press the gas pedal.
Further, check the fuel pressure, available over OBDII or directly on the rail.
Check for any air leak. All the hoses to the heads and throttle body, including dip stick, etc. Remove and clean the air flow meter. Try with the air flow meter disconnected. Check all the fuses, too.
Best of luck, keep us posted.
Old Apr 12, 2018 | 09:36 AM
JagV8's Avatar
It's such a rare code. If it's correct you already know what will have to be done (fix the PCM - there are repairers such as ASI - or, and you don't want to do this, replace it) but I wonder if it just might be a dubious battery? Fairly easy to check.
JimC64
Sep 22, 2025 02:52 PM
Steve Lane
Jan 12, 2017 08:14 PM
uk4545a
Sep 1, 2009 07:51 PM
chicago bob
Mar 14, 2008 09:05 PM
Jan 9, 2007 04:21 PM
