xk8 code p1797
Old Aug 23, 2014 | 05:02 PM
ali123's Avatar
Default xk8 code p1797
Ladies and gentlemen, I need some help on my 1997 xk8, I am getting the check engine light and every once in a while i get the stability/traction control fail messages and also the gearbox fail message. There is no actual problem with the car when I drive it around town, I would just like to figure out these troubles before it progresses to something bad or it causes me to get into an accident. I plugged in a ebay obd 2 code reader and got the code p1797. I looked at previous threads and did follow some advice. I replaced the battery with a new one, reset the ecu, and checked the connections at the ecu and tcm for wear with no avail. I do not know how to approach this problem next. Your help will be gladly apprecaited, thank you.
Old Aug 23, 2014 | 06:29 PM
cjd777's Avatar
P1797 Neutral Switch Circuit Malfunction
Read more at: Jaguar Check Engine Light DTC Trouble Codes
Copyright © OBD-Codes.com
Ali, this is all I could find and really not sure where to go from here.
P1797 Neutral switch malfunction.
Wayne
Old Aug 24, 2014 | 04:31 AM
ali123's Avatar
Oh the error sorry I forgot to mention the error means CAN TCM/ECM Circuit Malfunction, and when I said I checked the connections at the ecu/tcm I mean I simply looked at them, I did not do anything but I heard some people use a volt meter to check the connections etc... Should I do that or any idea what I should check next? thank you
Old Aug 24, 2014 | 02:32 PM
ali123's Avatar
no one... any general ideas??? thank you
toronadomike
Jan 22, 2026 10:13 PM
philwarner
25
Jun 26, 2021 05:43 AM
CXJ
Nov 28, 2015 11:41 PM
thefixer
Sep 11, 2015 09:17 PM
Bowman
Sep 3, 2015 03:17 PM
