XK8 Convertible Top Hydraulic Issue
Old Jun 26, 2012 | 08:37 PM
JimGXKR's Avatar
Thanks Gus.
I did a search and did not come up with the shopping list thread.
I look forward to you putting together a kit as this is something I want to do ASAP.
JimG
Old Jun 27, 2012 | 06:15 AM
Originally Posted by Gus
Walt and I worked together many times and had a great deal of dialogue over the hoses and valve. Yes Walt (LSI) will not be distributing it but I am looking to take it over. I will give an update when I can work this out.
Let us know when you get it together Gus, I'm sure a lot of people won't want the hassle of sourcing all the parts for themselves.
Old Jun 27, 2012 | 07:16 AM
Gus's Avatar
Gus
Not a problem.
Old Jun 27, 2012 | 10:40 AM
Good move Gus, there should be plenty of demand.
Pleased I've got a tin roof on mine!
Old Jun 27, 2012 | 02:36 PM
Gus's Avatar
Gus
You should see the results of our (Walt & I ) conversation within a few days.
Old Jun 27, 2012 | 02:39 PM
walt_00XKRConv's Avatar
Smile Relief valve kits
We put in an order for another batch of relief valves kits today. The delivery is about 4 weeks so I'll post when they are available again. I originally made the kit available when efforts to get group purchases didn't go anywhere. This was two or three years ago. If people buy them we will keep them available.
Old Jun 3, 2016 | 09:33 PM
Ted Zurawski's Avatar
Has anyone ever gotten hoses from Cabriolet Hydraulic in Fla. Need to order some new hoses and don't want Jaguar ones this time. How often do I need to change oil on the system?
Thanks,
TedZ
Old Jun 4, 2016 | 06:48 AM
  #28
RJ237's Avatar
I know nothing about them. Many of us have used Top Hydraulics for cylinder rebuild and hoses, link below. As long as you have the green Pentosin CHF11S fluid you will probably never need to change.
Jaguar Convertible Top Hydraulic System Rebuild/Upgrade Service - Top Hydraulics, Inc
If you have not done so, please visit the new member area and introduce yourself.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jun 4, 2016 | 06:50 AM
Ted - yes - I've had the Cabriolet Hydraulics hoses for about 3 years now and am very pleased with them.
As long as you are using the Pentosin CHF-11S fluid I don't believe you need to change it. If you have the older fluid - it will gel in the lines and cause problems
Old Jun 4, 2016 | 07:22 AM
  #30
Ted - Gus's website jagrepair.com also has a couple other options for replacement hoses but here is a comparison I did when I needed to replace mine- prices are from 2013 when I bought my hoses from Cabriolet Hydraulics but gives you an idea of the differences between the 2 companies:
The original hoses are rated at 3000psi with operating pressures around 1600psi
CabrioletHydraulics are the stainless steel braided ptfe rated at 450degrees and a burst rating of 12000psi. For a set of all 6 hoses $580 or $550 with core. I only needed the 4 cylinder hoses as the latch hoses had been replaced - so the 4 are $350 with core. The hoses also have a 3year warranty.
Top Hydraulics uses a kevlar reinforced hose with a 23000PSI burst rating and a set of 6 is $600
I have seen several in the forum recommend Top Hydraulics. I contacted a local vendor but they wanted $1000. A local convertible repair shop recommended Cabriolet Hydraulics for the hoses - so I guess I went with the less impact to wallet route since I want to do some other work
Old Jun 22, 2016 | 12:40 PM
  #31
loconnell's Avatar
Default 03 xkr conv top wont move
replaced complete set of hoses on 03 xkr conv worked good for a while then wouldnt close completely so i added fluid and now nothing was able to tilt reservoir up about 3 in it worked so reinstalled pump and now nothing again opened bypass and roof latch roof latch wont release all the way any suggestions mike
Old Jun 23, 2016 | 06:47 AM
  #32
BlkCat's Avatar
Mike,
Several years ago I removed and replaced the pump. The top did not work after I re-installed the pump. It has been a while but I think I could hear the system operating, but no movement of the top. I kept trying and it eventually started to work.
You may have air in the system that needs to be "work its way out". There is no formal bleed system. Operating the top eventually lets the air out of the system. I do not understand how that works, but it does.
Hope that is the problem. If it is, it is an easy fix.
Jack
NTL1991
XJ40 ( XJ81 )
Sep 24, 2015 09:09 PM
msdg137
Sep 16, 2015 06:24 AM
reedmtn
Sep 5, 2015 08:04 AM
jbjb_007
Sep 1, 2015 02:02 PM
Jandreu
Aug 29, 2015 07:31 PM
