Xk8 drivers window
Old Jun 10, 2013 | 12:06 PM
benxk8's Avatar
Default Xk8 drivers window
Hi
I have a problem with the drivers door window on my 1997 xk8
conv
I have a drivers door open warning on the dash, window
doesn't work at all so it wont seat when the door is
closed. the mirrors don't work either side and although the
passenger window operates from the passenger side it won't
from drivers side. I have swapped over the door control
modules so I don't think its that,also changed the micro
switch on the latch and put a new battery on all to no avail. this problem has been
coming and going intermittently for about a year and is
getting worse. Any help will be much appreciated.
Old Jun 10, 2013 | 02:42 PM
smoggyx100's Avatar
Originally Posted by benxk8
Hi
conv
I had similar problems that were cured by cleaning the door loom electrical connector and making sure it was properly seated.
regards
Old Jun 11, 2013 | 02:17 AM
benxk8's Avatar
Thanks Smoggy, will try that today. this one is really baffling me
Old Jun 13, 2013 | 04:41 AM
benxk8's Avatar
Many thanks Smoggy. You were spot on. Thankyou
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Razor
Aug 28, 2019 08:34 PM
GordoCatCar
Jan 2, 2017 01:10 PM
sadepol01
Sep 11, 2015 05:26 AM
