Xk8 gearbox
Old Jun 17, 2022 | 03:25 PM
Reika's Avatar
Default Xk8 gearbox
Hello, I have a question. My xk8 reaches 100km/h in 9 seconds, which is very slow. Previous owner changed the gearbox, put the one from bmw 7 series. As I understand, all the settings left from bmw and it ruins the potential performance of my jaguar. Is there a possibility to tune and to adopt this gearbox? How can I fix this issue?
Old Jun 17, 2022 | 06:56 PM
Jon89's Avatar
Call ZF Technical Support to discuss this issue with them. You will need the proper ZF product number of whatever transmission was installed in your car in order for them to have a chance of helping you....
Old Jun 18, 2022 | 12:06 AM
Reika's Avatar
Unfortunately, in this country there is no ZF tech support. Bmw e38 cars used the same gearbox as xk8. Is there a possibility to tune sth in this type of gearboxes? To make gears shorter, for example, or sth else?
Old Jun 18, 2022 | 01:48 AM
Pistnbroke's Avatar
No technical support in this country ?
If you filled in the details we would know where you live .
You could e mail a country which does have support ..eg Germany.
Does the sport button make any difference?
Old Jun 18, 2022 | 03:51 AM
Reika's Avatar
In lithuania. 9 seconds is in sport mode, with traction control off. It just drives like a regular car, not like a sport one. I am almost sure, that the problem is in gearbox.
Old Jun 18, 2022 | 04:22 AM
Pistnbroke's Avatar
this is a gentleman's cruiser ..If you put the pedal to the metal from a standing start it will go like a scalded cat .
If you have had the battery disconnected you must turn on ign and move accelerator to full throttle and back slowly a couple of times or it will go slow slow slow.
Old Jun 18, 2022 | 09:08 AM
Dr. D's Avatar
Can we rule out the very common throttle cable stretching, and that under WOT, that the throttle cable adjustment does indeed open the throttle plate a full 100%?
Old Jun 18, 2022 | 10:06 AM
Reika's Avatar
I think we can rule it out, when it is a bit wet, you can get a burnout.
v6madness
Jan 26, 2018 01:51 PM
jagtoes
Nov 14, 2017 09:59 AM
matt0091
General Tech Help
Jan 20, 2017 12:14 PM
neil xk
Dec 11, 2008 06:54 PM
bill.adams
Aug 22, 2008 07:28 PM
