xk8 gearbox fault message
Old 05-07-2015, 02:15 PM
troyenetics's Avatar
Question xk8 gearbox fault message
showing codes p0730, p0720, p0734. Transmission shop guy said that speed output sensor and that i have to change computer as well and that has to be done by jag dealer….is this true, does anyone know where speed output sensor is located? I hate going to dealership as usually they give it to me with sand and glass as lube…..kinda painful….help?
Old 05-07-2015, 02:25 PM
also the car only has 50,000 original miles
Old 05-07-2015, 02:36 PM
brgjag's Avatar
what year?
Old 05-07-2015, 03:47 PM
RJ237's Avatar
Received 2,786 Likes on 2,229 Posts
If you have a 4.0 L with the 5HP24 the following will be of use:
https://www.jaguarforums.com/forum/x...rmation-78132/
You do not have to remove the transmission to replace, just the valve body. Do that first to see if you really have to replace the TCM, which I doubt. But if you do, get one with exact matching numbers and it may be plug and play. I bought a spare and it works fine.
If you do have to get a refresh, many independent shops can do this.
Please visit the new member area and introduce yourself and your car:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old 05-20-2015, 11:09 AM
thanks, gonna try to locate tcm, is it difficult to replace? and what parts needed, obviously tranny pan gasket and filter, also where is the ecu/computer located so i can check the connections? also i did register in new forums….appreciate all help. 2004 xk8 convertible, 4.2l v8
Old 05-20-2015, 01:31 PM
Default my problem child
do i have to order any other gaskets to drop the valve body?
Old 06-09-2015, 12:57 PM
zidjan's Avatar
Hey Troy, I am having similar issue...did you fix yours?
Old 06-23-2015, 03:38 PM
in the process of ordering parts, not sure how to tell if tcm is bad or not, getting on-line and ordering service manual, along with pan gasket and filter to start....rarely goes into "limp mode", guess theres one way to find out.
Old 06-23-2015, 03:45 PM
it is a 4.2l v8, 2004 xk8
Old 06-24-2015, 04:12 AM
jamdmyers's Avatar
Do yourself a favor and read some of the information in the DIY sticky on the top of the forum, you will then have a better Idea what's involved. Look for Transmission section within the DIY
philwarner
25
06-26-2021 05:43 AM
cissdm
05-03-2016 06:02 AM
picard
10-12-2015 11:56 AM
BSM
Mark V - X 420G
09-14-2015 08:35 AM
rsperle
09-12-2015 08:37 AM
Quick Reply: xk8 gearbox fault message
