XK8 Instrument Cluster faults
Old Feb 28, 2015 | 07:13 AM
robertcp2's Avatar
Question XK8 Instrument Cluster faults
Hello all,
As I am new to this site just want introduce my self as Bob from South Carolina. I Recently purchased 2000 XK8 coupe with 52k original miles from a donation auction (site unseen). The car is beautiful runs great Black on Black. Don't know very much about these cars, previously owned a 1973 XJ6.
Now for the good stuff! check engine light on abs on, brake light on, all gauges inop, warnings are incorrect part fitted, ASC not available, gear box fault, low brake fluid, When I turn on the ignition I get an error on climate control followed by 10 beeps, then it works. Finally codes P1638 & P1000. Cleared P1638 never came back, still same issues. Did the hard reboot thing with the battery and it is fully charged at 12.5V. So I sent the instrument cluster to Circuit Solution's in ID, they tested said communication was work on the can network, did some soldering, cleaning etc.
Now I reinstalled and it does the same thing??
Every once in a while it all clears for a second or too and then returns to the original faults mentioned above. Any body have any suggestions? I've cleaned and checked the right rear wheel sensor so far, checked all fuses. Found one blown 20amp in the passengers side dash fuse box don't know what it was for, it was half way down the panel.
Thanks in advance,
Bob
Old Feb 28, 2015 | 08:28 AM
ccfulton's Avatar
Does the fuel gauge work?
Reason I ask is that the fuel gauge is an analog type direct form the sender but all the rest are communication from the ECU. If it is these communication type that don't work then you most likely have some issue with the CAN bus on the car, which is also consistent with the P1638 code.
The instrument cluster acts as a sort of bridge between the different networks In the car so all manner of strange, seemingly unrelated things may happen when there is a communication fault.
Unfortunately this kind of fault will be difficult (and potentially expensive) to diagnose with the guess and check method of replacing parts.
Really the best option is to find someone with the dealer level of scan tool that can talk to all of the various modules to help point you in the right direction.
Old Feb 28, 2015 | 08:40 AM
DaveInVA's Avatar
I would also reseat the connections to the ECU and reseat the instrument cluster fuse. Does the cruise control light come on when switch is pressed when dash is failing? Its on the same fuse.
Dave
Old Feb 28, 2015 | 08:52 AM
WhiteXKR's Avatar
The instrument cluster should also be checked for this known fault: http://jagrepair.com/images/TSB/XK8/...%20failure.pdf
Also check the connectors for bent pins (disconnect battery first).
Old Feb 28, 2015 | 09:01 AM
motorcarman's Avatar
I performed DOZENS of SERVICE ACTION S484 back in the early 2000s.
Once the solder migrates and shorts between circuits, it's sometimes TOO LATE to clean the solder and return the INSTPK to service. (damage done)
You can grind away the plastic ridge in the INSTPK backing plate to duplicate the updated 'M' version. You will probably need a replacement cluster. Make sure the replacement has the 'M' or at least follow the S484 instructions.
bob gauff
Old Feb 28, 2015 | 09:15 AM
robertcp2's Avatar
The fuel gauge also goes out..
Old Feb 28, 2015 | 09:24 AM
robertcp2's Avatar
Yes the cruise light stays on, but now not sure about gas gauge it reads 1/4 tank with or without codes.
Old Feb 28, 2015 | 09:26 AM
robertcp2's Avatar
Check all ecu & tcm connectors, pins etc. cleaned unplugged inspected
Old Feb 28, 2015 | 09:32 AM
Originally Posted by robertcp2
As I am new to this site just want introduce my self as Bob from South Carolina. ..........
Welcome to the forum Bob,
Old Feb 28, 2015 | 09:33 AM
robertcp2's Avatar
bob gauff
They told me at Module Master that the instrument cluster passed the bench test and had full communication with the CAN.
Old Feb 28, 2015 | 10:01 AM
jamdmyers's Avatar
Welcome to the forums, you'll find a host of information and a bunch of folks who really help each other out. You have one or more problems likely, depends on how long the car sat and where, what was wrong with PO and maybe why it was donation but regardless, here's a list of ground points, you should check these to ensure all your grounds are clean and tight. Probably not the problem but very Cheap.. a rarity with our jags.
File Type: pdf
Old Feb 28, 2015 | 10:20 AM
robertcp2's Avatar
Thanks, car is very clean like it was new and stored inside all its life, It still has 10 year old tires half worn according to the DOT code. No ground problems! Do you know where I can get a copy of the fuse box identifications. I know the locations just can not identify the systems it protects...
Old Mar 1, 2015 | 06:36 AM
jamdmyers's Avatar
Here's a listing made by a member here, sorry forget who but he gets the credit for this not me, I'm just passing it along, 02 isn't much diff than yours I believe they are the same.
btw: when you gt a min update your profile 'signature' with Year/Make so we'll know in your posts what MY your car is (I looked at top entry but in future posts it's good to know, you'll see most folks have this. Good Luck.
File Type: pdf
Old Mar 1, 2015 | 11:25 AM
robertcp2's Avatar
Default XK8 Instrument Cluster faults
Thanks all for the information, but I'm ready to pull my hair out (what I have left) trying to figure out this CAN communication error with the instrument cluster. I assume the cluster is good as I sent it out and it bench tested good tried all the other information I can see on this board. It looks like I will have to take it somewhere to diagnose.
Bob
2000 XK8 Coupe 52K miles forever.
Old Mar 1, 2015 | 11:33 AM
robertcp2's Avatar
Battery went from 12.5v to 12.25 volts over night normal or not? does it connected to car or disconnected same thing then after several days around 12v..
Old Mar 1, 2015 | 12:36 PM
Bob - how old is the battery?? You mentioned in the first post that it shows 12.5 fully charged but it should be 13. Have Advance Auto check the battery and charging system. If the battery is over 5 years old, I would consider replacing it
Old Mar 1, 2015 | 12:53 PM
robertcp2's Avatar
Thanks Steve, it is only 1 year old according to the receipt in the glove box, but when I checked, it was dry, so I added water and recharged.
Old Mar 1, 2015 | 02:08 PM
max224's Avatar
Due to all of the electronic systems in these cars, they can be pretty hard on batteries. If you research the forum, you'll find literally dozens of different problems caused by a questionable battery. The fact that the battery was "dry", so to speak, and you had to re-fill it, is worrisome. If the electrolyte drops well below the top of the plates, and depending on conditions (temperature, charging rate, etc.), it's overall life can be significantly shortened. You'd be well-advised to have it tested; of all the components you're looking at potentially replacing, the battery is probably the cheapest.
Old Mar 1, 2015 | 03:39 PM
RJ237's Avatar
A one year old battery shouldn't have lost that much water. It may be overcharging. But at this point you may need to replace it.
Old Mar 4, 2015 | 09:36 AM
robertcp2's Avatar
I put in a new battery today, and still have the instrument cluster faults. Same problem? Checked everything I could possibly do without a module scanner, I have no codes, Looks like I need the find a specialist here in Greenville SC..
