XK8 Purchase Possibility
Old Oct 4, 2023 | 10:00 PM
stevis05's Avatar
67camaro;
im glad to see your doing your homework on things….I didn’t.
I bought a very early production 97 coupe with 67xxx mi. I verified engine number which is difficult to locate but I have original engine with nikasil liners. However, this feature was a problem because back then all fuel had more lead in it than anything acceptable today. The fact that the mileage on my car was low and it runs great I am not worried about it at all. The car you’re looking at is way less mileage so I wouldn’t be worried at all about nikasil. And yes I admit I never compression tested each cylinder but after I did timing chain and tensioners update and water system and changed differential oil but this thing smokes tires if I want. I run highest octane fuel I can (usually 93) and I have no problems. Just my two cents on Thais part of your initial question.
now… engine serial number location on early cars(well mine at least but worth a look)
pop the hood, stand on drivers side of engine bay(us, left hand drive)
locate upper radiator hose from radiator on passenger side and follow it to the crossover/ thermostat housing. Look down between that and valve cover on drivers side and it might be stamped into the engine there.
tips; -have a good flashlight, maybe remove engine cover(just pull straight up) and have patience, and maybe a rag wrapped around a screwdriver with some carb cleaner to clean off surface if dirty.
Old Oct 5, 2023 | 01:03 AM
yamaha's Avatar
Nikisil not an issue ... Since year 2000 when sulfur was removed from the USA gasoline.
95 Cat
Jan 4, 2025 01:32 AM
NJJAGBOY
Dec 9, 2022 07:27 PM
Todd Wiens
Oct 2, 2021 11:02 AM
Rchuda
Jun 19, 2021 06:19 AM
Safari
Sep 28, 2014 12:31 PM
