XK8 Purge Control Valve
Old Jul 13, 2021 | 01:07 PM
sabumnim's Avatar
Default XK8 Purge Control Valve
Hello, Everyone, I am new at the forum so stay with me. I have a 2000 XK8 and cannot find a purge control valve. It show's as discontinued where do I go from here. HELP
Old Jul 14, 2021 | 02:23 AM
Welcome to the forums sabumim,
I've moved your question from US Northeast to XK8/XKR forum. Members here with the same model will be able to help.
Old Jul 14, 2021 | 11:10 AM
michaelh's Avatar
Hi sabumnim and welcome to the forum.
Which part # are you searching for? It is listed on Heritage so will be available:
https://parts.jaguarlandroverclassic...rol-valve.html
What symptoms are you experiencing that leads you to suspect the valve?
Old Jul 14, 2021 | 02:52 PM
sabumnim's Avatar
Hi michaelh, Getting a Po455 code from computer. Replaced
Gas cap moving on from that. Part #LJB 1515AB is what I need but not in stock
Old Jul 14, 2021 | 03:00 PM
motorcarman's Avatar
You probably need to test the EVAP system for leaks. Throwing parts at the problem can get expensive.
They make 'smoke-machines' for this purpose. Test and diagnosing is usually cheaper than guessing.
I had a BRAND NEW XK8 come into the Jaguar dealer a few days after delivery (probably about 2000/2001) that had the P0455 and it tuned out to be a torn 'O'ring seal at one of the carbon canisters. I simply diagnosed and replaced the seal.
The seal was torn at the factory during assembly. Warranty covered the repair but things happen.
Old Jul 14, 2021 | 03:25 PM
sabumnim's Avatar
Motorcarman Thanks for the advise, I'll look into that. I sure am glad I joined this forum. Stay well
Sabumnim
Old Jul 15, 2021 | 05:03 PM
Norm 427's Avatar
A few weeks ago the check engine light came on and the dash said for me to check the fuel filler cap but it was fine. The dealership did a smoke test and found no leaks. So they ordered a purge valve ... that was 2 weeks ago and no word yet.
Old Jul 15, 2021 | 07:30 PM
sabumnim's Avatar
Norm 427, That's interesting please let me know if you hear anything about the valve. I cannot find one anywhere and wondering what I will need to do if I cant find one.
Sabumnim
Old Jul 15, 2021 | 07:49 PM
michaelh's Avatar
https://www.roverjaguarparts.com/oem...alve-ljb1515ab
So nothing showed on the leak test?
Old Jul 17, 2021 | 10:13 AM
sabumnim's Avatar
Hi michaelh, Haven't done a smoke test. Will need to take it to someone for that. There is someone local to me that could do it I guess I just need to take the leap of faith.
Old Jul 17, 2021 | 10:32 AM
JayJagJay's Avatar
This info is cool...
File Type: pdf
Old Jul 17, 2021 | 01:46 PM
STLTHMSTA's Avatar
Once again, you guys come up with more helpful info. I printed this out for my reference later. Thankfully I have no such problems currently but I'm learning stuff all the time. Thanks Jay, Michael, Motorman, Norm. TM
Old Aug 27, 2021 | 05:36 PM
Norm 427's Avatar
The dealership finally discovered that Jaguar no longer makes the purge valves. And they cannot per policy order one from another source.
SO I discovered an independent shop that specializes in English cars and the owner owns 2 older Jags. Bingo! They did a smoke test and found the leak in an evaporative canister near the fuel tank. They said the canister had been hit by something and knocked the hoses loose therefore the leak. When they did the smoke test they did it with wheels on floor AND on a lift. On the lift was how they discovered the leak ... quite obvious. So it's assumed the dealership didn't lift the car to check for the leak. The indy shop repaired the bracket, hooked up the hoses and problem solved.
So no purge valve needed. BTW, I've found a new shop for my Jag!
crbass
Sep 22, 2019 12:48 PM
jandouglass
Apr 3, 2015 01:05 PM
lastgoodbye
Dec 16, 2013 11:03 AM
jimcaneer
Apr 7, 2011 09:32 PM
azad
Dec 30, 2010 02:07 PM
