xk8 rear suspension which bushes to change
Old Oct 31, 2014 | 04:27 AM
scoobie's Avatar
Default xk8 rear suspension which bushes to change
Rear subframe assy now removed.
Which bushes should I change as a matter of course and which if these should be poly bush.
Obviously I could polybush it all but I don't have deep pockets
Old Oct 31, 2014 | 09:38 AM
RaceDiagnostics's Avatar
If you plan to keep the car for a good while then if I were you, I would bite the bullet and polybush all the way, having scrimped when I did my front end only to have to do it all again, I wouldn't make the same mistake with the back end.
Old Oct 31, 2014 | 09:50 AM
Don't know if any of these are any good or not, listed in the how to section
. Lower Control Arms
. Shimmy Cured by Lower Ball Joints
. Sway Bar Bushes
. DIY Upper A-Arm and Lower Shock Bushing Replacement
. Upper Shock Mount Replacement (DIY)
. How To Replace Upper Suspension Bushings in Video by Reverand Sam
.How to Replace the Tie Rod Ends in Video by Reverend Sam
kelliott
May 31, 2022 05:26 PM
David Thompson
Sep 3, 2015 07:48 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
