XK8 rear view mirror falls off......
Old Nov 9, 2013 | 04:44 PM
hawkeye's Avatar
Default XK8 rear view mirror falls off......
If I hit a couple of bumps or cross railroad tracks with my '98 XK8, the rear view mirror falls off and swings in the breeze from its power cord. I'm able to slide it back into its mount, but it just falls off again.
I bought a tube of Krazy Glue, but one of the few things is says not to use it on is a rear view mirror. Why would that be?
Any ideas about how to fix it? Thanks!!!!!
Old Nov 9, 2013 | 06:39 PM
The Coupe's Avatar
One of our forum members, Gus, has a website with many repair procedures spelled out, and the loose mirror issue is one of them. A metal clip needs to be temporarily removed and CAREFULLY adjusted.
You'll find more info, with photos, here: Loose Mirror Repair
Old Nov 9, 2013 | 08:56 PM
motorcarman's Avatar
If you break the spring steel mount tab you will NOT be able to buy it separately (NSS).
Be careful and bend a little at a time.
bob gauff
Old Nov 12, 2013 | 03:20 PM
Burdedw's Avatar
The mirror on my 1998 XK8 fell off several months ago.
I found these instructions "loose mirror repair" and it worked like a charm!
I didn't have to bend the tabs very much for a good secure fit, be careful.
Thanks,
Dave B.
Old Nov 12, 2013 | 03:54 PM
batroute's Avatar
And just to emphasise be very, very careful removing and refitting the mirror to the mounting lug on the windshield - it must be kept parallel to the glass.
Old Nov 19, 2013 | 12:44 PM
hawkeye's Avatar
Thanks immensely for all the feedback.
The Loose Mirror Repair did not work for me. I tried it twice, and perhaps I was too cautious about breaking something.
Here's an alternative fix. I put a 3M Command medium size wall hook (#17091CLR-ES)upside down on the windshield wedged tightly against the bottom of the mirror's mount. It fits perfectly and the mirror doesn't vibrate. It's not too noticeable because the hook is clear.
I do wonder if the hot sun will affect the adhesive on the back of the hook. If not, I'm all set. Time will tell.
Thanks again!!!
99xk8guy
Sep 29, 2025 10:51 PM
FrickenJag
Jun 16, 2025 02:15 PM
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
