Xk8 still noises after timing chain / tensioners replacement
Old Jul 25, 2018 | 10:58 AM
stevepaa's Avatar
if you replaced the lower tensioners and ramps, did you include the spacer under the RH tensioner
if so, that is your problem, new tensioners do not use the spacer.
Old Jul 25, 2018 | 02:01 PM
neilandt's Avatar
Originally Posted by Brian XK8
Did you replace the lower tensioners as well as the uppers? If the lower tensioners are bad that may be the source of your noise.
Thanks for your input but yes I changed the lot.
Old Jul 25, 2018 | 02:02 PM
neilandt's Avatar
no I didn’t use the spacer,I’m thinking bottom end problem now.
Old Jul 25, 2018 | 07:18 PM
stevepaa's Avatar
likely
I do not know if you can get to rods from underneath
good luck
slanham
General Tech Help
Feb 1, 2014 06:34 PM
Bones28
Sep 10, 2012 12:44 PM
qwakwak
Sep 10, 2009 04:32 AM
