XK8 Suspension Questions:
Old Sep 24, 2015 | 02:22 PM
AntXJ's Avatar
Default XK8 Suspension Questions:
I'm getting ready to purchase suspension parts for a 2000 XK8 convert - base model. I want to keep the ride as factory as possible. Which Bilstein struts come standard on the early XK8s? I may purchase springs as well. Does anyone here have experience with lowering the car about an inch or so? Any concerns about handling and performance in general? Also, What strut mounts should be installed. I can't seem to locate OEM. Any insight would be greatly appreciated. Thanks!
Old Sep 24, 2015 | 02:32 PM
brgjag's Avatar
Jagbits or SNG Barrett, the sites couple sponsors can get you everything you need.
I have used both. If you need the parts ASAP Jagbits in my experience is much quicker but cost more, if you can wait use SNG.
Old Sep 24, 2015 | 06:30 PM
Jag#4's Avatar
If you want to keep the factory ride, lowering springs is not the way to go.
Mention the forum at SNG and get a 10% discount.
Parts Geek has the front upper shock mounts for $116 right now. Good price.
Be sure when you order springs you get the part number for convertibles. They have a different sprint rate than the coupes do. If you are doing coils and shocks, might as well get all the misc. pieces as well, like the bump stop and gaiters.
scooternva
29
Mar 25, 2025 12:45 PM
ogorir
Jan 18, 2016 10:09 PM
redgear
Sep 18, 2015 10:05 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Johnken
Sep 15, 2015 05:46 PM
